Another stalling issue
We finally got the car on the road about a month ago. It would run great in the garage, but when we started driving it, it would skip and sputter and hardly run. There seemed to be bubbles in the inline fuel filter and very little fuel. This is the setup and what we have done to try to fix it.
The car -- it has duel electric fans and no mechanical fan or shroud ( never runs over 205 ). The engine seems to generate a great deal of heat -- we did not rebuild it (matching #s). The car sat for 25 years ( last inspection was in 1985 ).
We put tight tuck headers and dual exhaust all the way back. The headers are wrapped.
We dropped the tank and cleaned it out, blew through the lines and filled it up with gas. This made it a little better, but would stall while driving at a steady speed after about 15 to 20 minutes.
We replaced the mechanical fuel pump with the Mr. Gasket version of the Holley Blue ( 105 gph ) and a regulator with return. We insulated the fuel lines the best we could where we could. This might have helped a little more, but still stalled after driving for a while.
I put a new Holley 4160 carb with elec choke on and that made it run great ---- until it stalled again. It runs great then starts to hesitate until it stalls. After it stalls and you stop it will start right back up and run a while before it stalls again. When it stalls and you turn the key back on the fuel pressure is 0 - 1 and there is little or no fuel in the filter. It will start and run fine and the pressure builds to around 8psi.
Before you say ignition -- I just put a new Accel 59107 distributor on and set the timing to 9 b tdc and ~ 32 total. Oh yea -- it has new 8.5 Accel wires and new plugs. It still stalls while running at steady throttle ( rpm does not matter ) after about 15 mins at operating temp. Starts and will run immediately
The fuel pick-up is original in the tank ( top feed ). I have considered converting to bottom ( gravity ) feed.
There seems to be alot of heat under the hood, but it never overheats. I don't know how I could isolate the fuel lines from the heat any more and keep them in the car.
25 to 30 psi oil pressure, little or no smoke, and vaccum is 18 to 20 at carb base.
I NEED HELP --- IDEAS
