SBC rebuilding question
Old Sep 11, 2011 | 07:03 PM
LannyL81's Avatar
LannyL81
Default SBC rebuilding question
With the engine upside down; the crank gear dot at 12 and the timing gear dot a 6 so they are next to each other.....#1 is at TDC of which stroke....compression or exhaust?
Old Sep 11, 2011 | 07:31 PM
billla's Avatar
billla
St. Jude Donor '14
Looking at the engine upside down with the dots aligned, the crank key at 7:00 and the cam pin at 9:00 you're at TDC compression #6 and TDC exhaust #1.
The crank dot would need to be at 6, and the cam gear at 12 if it's aligned upside down...
Old Sep 11, 2011 | 09:07 PM
Tim H's Avatar
Tim H
Don't align upside down please.
Old Sep 11, 2011 | 09:09 PM
LannyL81's Avatar
LannyL81
#6 compression.....#1 exhaust.....that is what I thought....just wanted to be sure.
Tim H....????...what are you referring to???
To SBC rebuilding question
