quick blinkers Help
Old Sep 14, 2011 | 10:32 PM
bgall2's Avatar
bgall2
Default quick blinkers Help
Hey guys,
I have gotten so much GREAT information on this site. The blinkers on my 78 work but have started flashing erratically and fast...far removed from the "on, off, on, off" mode. I can live with it but I would like to fix it. Any ideas? I have changed the light flasher.
Old Sep 14, 2011 | 10:42 PM
M A Fry's Avatar
M A Fry
You haven't blown a bulb, indicators flashing very fast usually are a sign of a blown bulb.
Mark
Old Sep 14, 2011 | 10:49 PM
bgall2's Avatar
bgall2
Mark,
Thanks for the reply. I cant remember if I have changed all the bulbs or not. However, every blinker/bulb is flashing...just fast. No bulbs are out.
Bob
Old Sep 14, 2011 | 11:19 PM
sly vette's Avatar
sly vette
There are 2 different flashers on your car...1 is for the turn signals and the other is for the emergency flashers. Are you sure you changed the right one?
Old Sep 15, 2011 | 12:05 AM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
Flasher blinking fast is a indication of high resistance. Slow or no flash is low or open resistance .
Check for bulb installed incorrectly, wrong bulb installed, wrong flasher installed. short to ground in circuit.
Old Sep 15, 2011 | 06:36 AM
AAJC's Avatar
AAJC
High resistence was my problem (I think). The terminals into the flash unit were slightly corroded & caused quick flashing or none at all. I cleaned the terminals on both the wire end & flasher unit. It started working fine after that.
Hope this helps.
Andrew
Old Sep 17, 2011 | 11:25 PM
bgall2's Avatar
bgall2
One light flasher is on the circuit breaker panel and the other is on a line inside the center console....is this correct? But I do not know which is which.
To quick blinkers Help
