Front coil springs
Old Sep 15, 2011 | 12:47 AM
Ralphbf's Avatar
Ralphbf
Default Front coil springs
I'm looking for FRONT 460 LB GRAND TOURING springs but
I want to lower it an inch.
I've looked around but have not found a replacement spring that does what I want.
Any suggestions?
Ralph
Old Sep 15, 2011 | 01:55 AM
jerome1979's Avatar
jerome1979
cut your spring !
many have done this
Old Sep 15, 2011 | 09:55 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
If you cut your springs your going to increase rate. You can also use the BB springs (550# rate) and that will give you 3/4"-1". Different factors will determine how much the front end will come down. If you have replaced heads and intake, for instance, to aluminum than the drop will not be as much. AC will also have an effect. If you do cut your coils, it's going to be a PITA, but I would only cut a 1/4 coil each time and reinstall. Your going to have to trial and error the whole deal until your happy with the look.
Old Sep 15, 2011 | 11:49 AM
Shark Racer's Avatar
Shark Racer
I agree. Start with the 550# springs and go from there. Honestly, I didn't see a huge ride difference from the 460 vs the 550. My car is originally an FE7 car (550# front, ~292# rear 7-leaf) and some hooligan installed the 460s at some point. Car looked much nicer with the 550s, and rode just fine.
And the alum heads took me close to where I started when I made that swap...
Old Sep 15, 2011 | 01:41 PM
Ralphbf's Avatar
Ralphbf
If I want a stiffer spring, and I do, and a lowered front why not just cut 1/2 a coil off and reinstall.
I do have aluminum heads.
Maybe a whole coil removed would be okay.
Someone else actually remove a whole coil and been happy?
Old Sep 15, 2011 | 02:30 PM
Shark Racer
Do you have the 300# springs right now? or something else?
Old Sep 15, 2011 | 03:38 PM
Ralphbf's Avatar
Ralphbf
What ever a 1975 corvette came with.
Sorry that's all I know.
Ralph
Old Sep 15, 2011 | 04:03 PM
69vettester's Avatar
69vettester
I have 460# springs/bilstein shocks, The springs installed, lowered the front about an inch when I did it.?
Old Sep 15, 2011 | 04:21 PM
noonie's Avatar
noonie
Here is a 75 with the stock spring cut 1 coil off the top and 245/60/15 front tire.
Old Sep 15, 2011 | 04:25 PM
69vettester
Dont cut the Coil, They are balanced similar to a tuning fork.
Old Sep 15, 2011 | 05:16 PM
palmbeachvette76's Avatar
palmbeachvette76
I replaced my stock '76 springs since with the VB&P #550 springs and it dropped close to 2" which was what my car needed.
Before:
After:
Left spring is stock - Right is #550
Old Sep 15, 2011 | 06:09 PM
Shark Racer
That actually doesn't looks like the "stock" spring. There's quite a different number of springs available over the 68-82 run, but the most common were a very tall, thinner wire spring (~300#) and the thicker, shorter ~550# (looks very similar to the "new" spring)
I'm guessing someone put 460# springs in your car at one point. That's what happened to mine, although my car was originally FE7, which gave it the 550# springs.
F41 is another early package that would have given the thicker, shorter springs.
The 460 and 550# springs will come out without a spring compressor, the stock base springs will require an internal spring compressor to get them out.
Saying "stock spring" is very ambiguous - there's about 7? different front springs listed for the 78 MY alone, although they tend to group "tall/thin wire" and "short/thick wire" as mentioned above.
The 460# springs were NEVER a stock application, it was an aftermarket creation. If you already have 460s, you can cut ~2 coils off and essentially have a 550. Look at that picture and you'll see what I mean.
Old Sep 15, 2011 | 06:45 PM
Ralphbf's Avatar
Ralphbf
Before:
After:
That's the look I'm aiming for.
What size tires and rims do you have on it?
I'm looking at 255-50-17 all the way around.
But I see where some go much larger on the rear.
I've already ordered the rims, just waiting for them to show up.
Ralph
Old Sep 15, 2011 | 08:13 PM
boltnut's Avatar
boltnut
Why not just go with adjustable coil over shocks ?
Old Sep 15, 2011 | 10:17 PM
palmbeachvette76
Ralph
The wheels are Centerline Champ 506 18" x 8" with a 4" rear space. Tires are 255/45ZR18 which are 1/2" shorter than the factory 15" tires but wider
Old Sep 15, 2011 | 10:25 PM
palmbeachvette76
I certainly can't and won't argue with you but based on the overall conditon of this car and after unrigging all of Bubba's rig work I didn't find any physical indication when I rebuilt the front end with Moog parts that this thing had ever been apart or worked on. Doesn't mean someone didn't but if they did it was along time ago.
The shocks I removed were factory and the ball joints and control arm bushings all appeared to be original.
I did buy a spring compressor but it didn't fit through the shock hole in the lower control arm so I loosened the control arm bushing bolts and pushed it down as far as it would go which allowed enough room to remove the spring with a big pry bar so who knows.
I would be curious to know the measured length difference in a relaxed state between the 460 and 550 and a "stock" spring just to know what kind of difference each one has, doesn't matter now I just enjoy knowing new things.
Old Sep 16, 2011 | 02:40 AM
Ralphbf's Avatar
Ralphbf
palmbeachvette76, So how is the ride with the springs and tires?
Did the spring come before the tires?
Ralph
To Front coil springs
Old Sep 16, 2011 | 07:41 AM
palmbeachvette76
Ralph
Springs came after the wheels by several months. Normal driving ride really didn't change at all, cornering with the lower stance and center of gravity improved and later I added a larger front sway bar from VB&P which made things even better. No regrets at all with this mod and would highly recommend it not only for the much improved look but the score on the fun meter went up a few notches
Old Sep 16, 2011 | 08:04 AM
Ganey's Avatar
Ganey
Ralph
palmbeachvette76, So how is the ride with the springs and tires?...
Ralph
Check for rear 9 leaf std. or 7 leaf w/ rear sway bar FE-7.
If you have to ask about ride, you are probably right about 460 for you.
Don't expect any good comments on FE-7 "ride".
I have the FE-7 (550 ft.) & really like it!
Old Sep 16, 2011 | 11:36 AM
Shark Racer
If you could get it out without a spring compressor, it's not the base model spring. I've not removed one myself, but every account I've heard has said that a spring compressor is required. Even with the control arm decoupled at the ball joint, the base 300ish # springs won't budge.
Like I said above, a 550 looks like a 460 with two coils removed - the wire diameter is more important. The 300# spring is much taller.
The photos are perfect examples of 460 and 550s. That's what it looked like when I removed the 460s from my car.
Per the MVMA specs, a 300# spring will have the following specs:
15.45" height, 9 coils, wire diameter 0.609"
The 550# spring is 13.14" free height, 7.25 coils, 0.68" wire diameter.
Well, I've been wrong before and I still could be this time. If you still have the old spring, you could measure it with a caliper to get the coil diameter and then we'd both know for sure.
