Curb weight or overweight?
I really need a TIG so I can start making aluminum parts to get back under 3000lbs
Me out of the car
1/2 tank fuel
200r4 trans
C5 seats
electric fan
Long tube headers
No smog or computer system
Fiberglass rear spring
Spare tire in place
Factory alum. slot wheels
Cast iron heads
This is a early 81 car
BTW-My 2010 Z06 is listed as 3,080 lbs!
Lance P.
Curb weight is defined on the same page as a calculated value of a vehicle with std equipment only, as designed, with the additional load of oils, lubes, coolant and fuel - all filled to capacity.
Shipping weight - as curb weight but only 3 gallons of gas.
The same specs indicate the dry weight of the L-82 as greater than the L-48 (640.7# vs 622.4#).
I've always heard that the 78 was actually the heaviest of all C3's - I always assumed it was because of the rear glass as well.
Optional weights for L-82 are;
A/c 67#
P/W 8#
Gymkana 7#
AM/FM 13#
AM/FM/8T 15#
TILT/TELE 2#
HD Battery 5#
L-82 20#
auto trans 34#
So my L-82 car would have broke the scales at 3679# (3557+67+8+7+13+2+5+20)
At 6.1#/gallon thats a 42.7# delta right there from the previous year.
A/c 67#
P/W 8#
Gymkana 7#
AM/FM 13#
AM/FM/8T 15#
TILT/TELE 2#
HD Battery 5#
L-82 20#
auto trans 34#
I am perplexed though about a few items:
I am assuming that the gymkhana suspended cars weight +7 lbs mostly from the fact that the L-82's having a heavier front sway bar and a rear sway bar but the 9 leaf steel spring versus the 7 leaf on the gymkhana cars has to be pretty heavy. The composite 360 spring I have deducts 42 Lbs alone.
The L-82 weighs +20 which has to come I assume from a heavier crank (forged) and 4 bolt main bearing caps versus 2 bolt main bearings but it has an aluminum intake versus a cast iron manifold (big difference) and the L-82 has the AIR pump and associated hardware versus none for the L-48.
AM/FM/8 track is also gone.
My 78 L-82 has no A/C, no Pwr windows, no tilt/Tele, a modern battery which is much lighter than the HD battery in 78, no cast iron exhaust manifolds (McJacks shorties are much lighter), and no pancake cat (which is a big boat anchor). Also, the OEM mufflers are VERY heavy versus Monza turbos/Magnaflows and no cat. Then you have to add the 24 gallon tank (appx 150 lbs) which you are right is very heavy full of gas. Delete the weight of the T-tops which I hardly every carry with me in the warmer months (rain shade) and deduct the aluminum radiator and water pump (how much?).
The SLP rims are lighter than the OEM aluminum rims as well (not sure how much?)
So where am I with my 78 with a 1/4 of tank of gas today and a 4 speed an aluminum water pump and radiator? Probably around 3,450 to start. Composite spring, no cat (s), shorty headers, lights mufflers, no t-tops, much lighter battery, lighter wheels etc-best guess 3,300 lbs-Not too bad. 3,100-3,200 Lbs would be much better! Aluminum heads would probably get me to 3,250.
With all this said, I need to weight the car with minimal gas, no t-Tops, and no driver.
PS-The stock seats are very heavy versus some others!
I would venture to say the springs between the 9 and 7 leaf are nearly a wash as the 7 leaf uses thicker leaves than the 9.
Either way, the 78 starts out pretty porky dont it
In process of removing misfire injection, gotta be a few pounds. Future includes aluminum heads, aluminum master cylnder, removal of stock fan & shroud (electric fan)...
Carl
Scott
In process of removing misfire injection, gotta be a few pounds. Future incudes aluminum heads, aluminum master cylnder, removal of stock fan & shroud (electric fan)...
Carl
