I measure 5 and 1/16th from the block just above the bracket to the front lip of the pulley on the power steering pump and it is still not out far enough to line up.
MIke I checked all of the measurements you put in this thread. They are all dead on with what I have on my balancer pulleys. I am guessing the problem lies with the power steering pump. Is there a possibility that this is not the correct pump for my far and I need a flat pulley? THe balancer pulleys line up with everything else, the water pump, the a/c and the alternator. the only one that does not line up is the power steering.
This is a possibility. My PS pump has the pressed on pulley. Yours appears to be held on with a nut? I will get the measurment from the front of the block to the front edge of the PS pulley. mike...
Mine shows 5 1/4 in. from the front surface of the block to the front edge of the PS pump pulley. I measured this with the belt installed. The closest reference point in line with the PS pulley is the front edge of the "freeze" plug hole on the front drivers side of the block. This measures 4 7/8 in. from its front edge and the front edge of the PS pulley. Hope I am helping. mike...
That is within 1/4 in. of mine. I am no longer much help. Hopefuly some of the more experienced guys will know what we are missing. I will watch and see how you get along. mike...
OH!! Are you measuring with the nuts/spacers in place?
