pulley problem
Old Sep 16, 2011 | 10:28 PM
azguy's Avatar
azguy
Default pulley problem
I had to space out my power steering pulley a 1/2in to line up with the engines pulleys when I got my new motor. the problem is not my alternator belt rubs against the bracket. does anyone have any ideas on how to fix this? THese things are really pissing me off
Old Sep 16, 2011 | 10:32 PM
scottyp99's Avatar
scottyp99
Could you explain your problem a little more clearly? I have no idea what you are talking about. Something about belts and pulleys not lining up?
Scott
Old Sep 17, 2011 | 12:07 AM
azguy's Avatar
azguy
I had to space out the power steering bracket a 1/2 inch in order to line it up with the pulley that comes off of the harmonic balancer. when I tried to put the belt onto the alternator I noticed it rubs against the bracket for the power steering steering pump. I cant figure out how to get the power steering pump to line up and not have the alternator belt rub against it. it sticks out too far. Does that make sense? I can take pictures in the morning but its too dark out right now.
Old Sep 17, 2011 | 07:13 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
If you have to move it that far (1/2 in. is too much), then you must be using either the wrong bracket or the wrong pulleys, to get a better help you have to give some more info. about your car (year, engine, options .. etc).
Old Sep 17, 2011 | 10:27 AM
azguy's Avatar
azguy
its a 1978 still has the 350. they are the same brackets I took off of the car but a different block. it has a/c, water pump and alternator pulleys only no smog. I will get some pictures this morning
Old Sep 17, 2011 | 11:51 AM
bluthundr's Avatar
bluthundr
A picture might make it easier to get you some good advice
Old Sep 17, 2011 | 12:07 PM
Richard Cooper's Avatar
Richard Cooper
Dumb question but..... are you sure the harmonic balancer in on the shaft all the way? I just installed a new crate motor and I thought I had the balancer installed al the way. I also had a alignment problem and a friend found that the balancer was not all the way back.
Old Sep 17, 2011 | 01:52 PM
azguy's Avatar
azguy
I didnt install the balancer myself the guys who rebuilt it did that. The only one the doesnt line up prefectly is the power steering pump.
Old Sep 17, 2011 | 03:08 PM
myk7's Avatar
myk7
Was that the power steering pump/pully you pulled off the old motor? Is it possible you have another laying around and picked up the wrong one?
Old Sep 17, 2011 | 03:46 PM
scottyp99's Avatar
scottyp99
OK, so it all lined up on the old engine, but now on the new engine, they all line up except the power steering pump? Well, it's not hard to figure out that you must have put the bracket back on incorrectly somehow, because the block is no different from the old one. That's one of the nice things about small block chevys, they are all pretty much identical on the outside.
Scott
Old Sep 17, 2011 | 05:37 PM
bluthundr's Avatar
bluthundr
Here is how it looks on my 76, plenty of clearance.
Old Sep 17, 2011 | 05:40 PM
bluthundr's Avatar
bluthundr
I'm wondering the same. Your pulley looks concave, mine is just flat. That may be why you had to shim it out.
Old Sep 17, 2011 | 06:12 PM
azguy's Avatar
azguy
I only have the one I pulled off. So there is no chance I mixed them up. I didnt see if it lined up when I pulled it off though, I was pulling the engine so I didn't think to check. The brackets for the power steering pump can only go on one way, they are pretty dummy proof. Even I couldn't mess that up. I looked at zips website and it says the 75 to 82 use the concave one. I will put it on without it spaced out and take a picture so you can see it that way too.
Old Sep 17, 2011 | 06:27 PM
hugie82's Avatar
hugie82
Just checked my pulley and its almost flat too. My pulley almost hits the frame by 1/4-1/2 inch by the indent in the frame for clearance.
I had to get pulleys and brackets for a 74 vette I converted to a big block chevy. I got almost every bit from DrRebuild. His catalog has detailed picksof every year but he has a very small web site.
Old Sep 17, 2011 | 06:47 PM
mds3013's Avatar
mds3013
First thing. The alt. belt is hitting the bolt heads due to the nuts behind the front PS pump mount. That mount fits up against the rear PS pump mount that has the motor mount bolt through it. You know this I am guessing and the nuts are your 1/2 spacers. Correct? mike...
Old Sep 17, 2011 | 07:08 PM
mds3013's Avatar
mds3013
The gap between the front of the timing chain cover and the back of the harmonic balancer is a little less than 3/8in. The pulley stack is 1 5/16 in. from the front of the balancer to the front edge of the PS pulley. Does this match yours? mike...
Old Sep 17, 2011 | 07:51 PM
azguy's Avatar
azguy
You are correct mike, the nuts are my spacers. I have all those same diagrams so I know I put it together correctly. here is what the belt looks like set up without spacers.
To pulley problem
Old Sep 17, 2011 | 08:00 PM
mds3013's Avatar
mds3013
OK. Something is going on with the balancer and pulleys on the crank. Give us the distance from the front of the timing cover to the front edge of the front pulley. My '77 is 4in. exactly. mike...
Old Sep 17, 2011 | 08:10 PM
myk7's Avatar
myk7
Looks like the water pump pullies are lined up with the crank pullies. It appears the PS pump is in crooked. I'll measure the distance from my PS pully to the pump in a few minutes.
My PS pump is different than yours, but the distance from the pully to the block (just above the ps pump bracket) is a tad under 3 3/4 inches
Old Sep 17, 2011 | 08:32 PM
azguy's Avatar
azguy
MIke I checked all of the measurements you put in this thread. They are all dead on with what I have on my balancer pulleys. I am guessing the problem lies with the power steering pump. Is there a possibility that this is not the correct pump for my far and I need a flat pulley? THe balancer pulleys line up with everything else, the water pump, the a/c and the alternator. the only one that does not line up is the power steering.
