steering gearbox removal
My question is... Do I have to remove the Pittman arm from the gear box shaft while it is in the car.
Or
Can the gear box be pulled from the car and the Pittman arm separated from the unit on my work bench?
79 Corvette
Complete instructions are available in the Chevrolet Chassis Service Manuals. The following is a scan:
http://jimshea.corvettefaq.com/wp-co...verhaulpdf.pdf
Having said the above, it is possible to obtain a reasonable adjustment (or at least determine where the lash is occuring) with the gear in the car. Here is a Microsoft Word paper on the subject.
http://jimshea.corvettefaq.com/?p=810
You must always set the sector shaft adjustment with the gear exactly on center. (There is lash in the sector shaft gears off center as they were manufactured. If you try to eliminate the off-center lash, you can damage the gearset when the gear comes back to center.)
If you want your gear rebuilt, I would suggest contacting Gary Ramadei. He is available through other Corvette websites.
Jim
How hard is it to remove the other end of the Pittman arm from the power steering unit?
Is it a taper fit, like the other end on the out put shaft? Or is it a keyed / machined fit?
Thanks for the help guys, This sure makes my life a lot easier
Jim
The rebuilt/blueprinted hand adjusted OEM box that I reinstalled was so much better than the factory built box it was incredible-it was that much better! The steering has good feel, is ultra responsive, and has zero play now. Gary is very reasonable with his prices as well for the amount of work that he puts into a rebuilt OEM box!
Every single other car I have-enough-has rack and Pinion steering and I have no desire to change my C3 steering to some other type now.
