Made my own alternator bracket!
Old Sep 18, 2011 | 11:21 PM
neuroclast's Avatar
neuroclast
Default Made my own alternator bracket!
Wanted to make my own instead of buying one, and was tired of the tension the big L gave and how it put the alt belt so close to the power steering reservoir.
Wooden template:
Right after casting:
Before paint:
After a really bad job of spraypaint:
Gonna use a turnbuckle to the rounded end to keep tension.
Old Sep 18, 2011 | 11:25 PM
daanbc's Avatar
daanbc
St. Jude Donor '12
That's great! Wish I could do that. Must feel good makin somthing your own.
Old Sep 18, 2011 | 11:38 PM
scottyp99's Avatar
scottyp99
You actually cast it? I would have just made a template and cut it out of stock. That's pretty cool! What is it cast from? Iron? Aluminum? Plaster?
Scott
Old Sep 18, 2011 | 11:41 PM
cv67's Avatar
cv67
St. Jude Donor '05
Scott
For sale:
1 slightly used cast kit.
Kid is using a sling didnt need it.
Old Sep 18, 2011 | 11:42 PM
neuroclast's Avatar
neuroclast
Scott
Yeah, I cast it. I don't have a CNC or access to one (or any other kind of mill), so I cast most things I need. It's cast of aluminum and just over 1/4" thick, so it would have been hard to cut out of anything by hand.
I have a small metal furnace so I melt lots of metal and cast lots of things.
Edit: oh I guess it's not obvious. The part is solid aluminum. The wood was just a template for sand, in which I poured molten aluminum to make the part.
Old Sep 19, 2011 | 07:15 AM
tekvette's Avatar
tekvette
Thats what I'm talkin' about!!!!!!! LOVE the home made stuff! It looks GREAT! Nice job!
Old Sep 19, 2011 | 10:41 AM
RobbSalzmann's Avatar
RobbSalzmann
St. Jude Donor '12
Very Nice!
Sooo, how much would you charge to make another one? I'll cheerfully supply a bag of empty beer cars!
Old Sep 19, 2011 | 10:50 AM
Dantana's Avatar
Dantana
Where do I pick up one of these casting set ups? I haven't seen any at the local garage sale!
Awesome.
Old Sep 20, 2011 | 07:56 PM
scottyp99's Avatar
scottyp99
Do you cast your own bullets, by any chance?
Scott
Old Sep 20, 2011 | 08:16 PM
billcarson's Avatar
billcarson
neuroclast that is very interesting what you did but as i usually do when i redesign something, i always try to somehow test it's strength.have you tested any of your castings?i too have altered my alternator mount with stainless steel hardware that i know won't crack.looks great btw and best of luck.
Old Sep 20, 2011 | 08:28 PM
neuroclast's Avatar
neuroclast
Originally Posted by RobbSalzmann
Very Nice!
Haha, sadly aluminum cans are a bad source of stock. The alloy is made for extrusion, not casting. I usually melt down carbs and other things to get good alloys.
Awesome.
Just grab some fire clay, make your own high BTU propane burner, and you can make your own!
Scott
No bullets. I could I guess, but I don't shoot much so I have no reason to.
I don't have any substatial equipment to test my castings, but I did hang 130lbs off of the tip and it held up fine. I could cast it from iron or stainless, but I see no reason to. That is overkill for the loads put on the alternator.
Old Sep 20, 2011 | 08:45 PM
AGVI's Avatar
AGVI
Canadian Events Coordinator
interesting...keep testing.
Old Sep 20, 2011 | 09:05 PM
Vette5.5's Avatar
Vette5.5
I'm curious of this too. While "neuro's" casting looks pretty cool, I've done my share of metal working over the years, and from experience that type of casting isn't very strong. Not trying to be a wet blanket, but no way I'd put that bracket on my car. If fashioned from flat steel stock, that would be another story.
Old Sep 20, 2011 | 09:23 PM
MN80Vette's Avatar
MN80Vette
If that cast aluminum bracket fits and works and I had that wood model, I'd have a few machined from flat steel. Our son is a CNC machinist.
Old Sep 20, 2011 | 09:27 PM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Very cool project neuro
Old Sep 20, 2011 | 10:25 PM
neuroclast's Avatar
neuroclast
I'm touched everyone is so concerned with my safety. This bracket is way more than strong enough to handle what it was designed for, which is to be a leverage point for a turnbuckle to tension a belt. It is already on the car and working.
It's not like I cast an aluminum u-joint to go on the axle behind my 383. All this has to contend with it a little drag from an alternator and the tension of the belt, something I think almost 3/8" aluminum can handle.
And just for the record, there are aftermarket kits with basically the exact same thing made out of aluminum being sold:
Old Sep 20, 2011 | 10:35 PM
RobbSalzmann
St. Jude Donor '12
I would feel like I could make anything at all if I could do what you did there.
Now that would be fun.
" The alternator's
connected_to_the
carburetor..."
I'm solving a similar need on my alt using a couple of 3/8x3/8-24 Heim joints and a piece of 3/4 DOM tubing. Sort of a panhard thing for an alternator bracket I guess.
EDIT:
I just saw the pic above this post after clicking submit. They sell them already made! Mine is about $14 before chrome. That one looks costy but very nice.
To Made my own alternator bracket!
Old Sep 20, 2011 | 10:42 PM
neuroclast's Avatar
neuroclast
" The alternator's
connected_to_the
carburetor..."
EDIT:
Yeah that's why I made my own. Buy that for $85 or take an hour to make one that is pretty much the same. No brainer.
Old Sep 20, 2011 | 11:58 PM
scottyp99's Avatar
scottyp99
The reason I asked about the bullets is because everybody that I have ever known who had a metal melting furnace had it for melting down lead for casting bullets for handloads. Until now, I guess!
Scott
Old Sep 21, 2011 | 02:26 AM
Bud2's Avatar
Bud2
Bud2
I'm a jeweller and cast stuff all the time, tho a little smaller. Glad to see someone else use 'ol time technologies'.
Bud.
