Backpressure?
Old Sep 21, 2011 | 09:07 AM
81pilot's Avatar
81pilot
Default Backpressure?
There is another thread running amuck from the original posters question so I decided to put forth a query based on a comment there. A lot of comments are made talking about (exhaust)backpressure and power. Is it not true that back pressure is only a factor in an engine that has a lot of valve overlap? It seems to me in a fairly stock or mildly modded motor it would be of no real concern, since the exhaust valve is basically only open during the complete exhaust stroke. Maybe I need to be educated, but it seems simple to me, but some people instantly say you must have back pressure and these pipes or those will lose power yadayadayada. My opinion is that in this case less is what you want....Maybe I am wrong if so please enlighten me...Thanks.
Old Sep 21, 2011 | 09:16 AM
Ganey's Avatar
Ganey
The less backpressure the better!
Old Sep 21, 2011 | 10:24 AM
69 Chevy's Avatar
69 Chevy
As I recall, the only engine that I've ever owned that needed some back pressure to operate at its best was a 2 stroke Yamaha SC500A.
Old Sep 21, 2011 | 10:38 AM
DRIVESHAFT's Avatar
DRIVESHAFT
Exhaust backpressure is a bad thing.
What confuses some people is the loss in low rpm power that can come from running pipes that are too large. Larger pipes don't always mean lower backpressure.
Pipes that are the correct size for the rpm range where you are operating will lead to a high velocity exhaust gas flow.
The fast moving exhaust will help to pull the gasses behind it out of the chamber, like siphoning a tank with a water hose.
There is of course a point where the pipe is to small and the high velocity will be counteracted by a pipe that just cant flow enough to get rid of all of the exhaust.
An overly large pipe results in lazy, slow moving exhaust gasses that only leave the chamber because they are pushed. This does not remove exhaust as efficiently as a smaller (correctly sized) pipe will.
Old Sep 21, 2011 | 12:02 PM
81pilot's Avatar
81pilot
[QUOTE=69 Chevy;1578758115]As I recall, the only engine that I've ever owned that needed some back pressure to operate at its best was a 2 stroke Yamaha SC500A.
Yes, on a 2 stroke motor with reed valves, the backpressure actually assists to close the reed valve all the way.
Old Sep 24, 2011 | 09:10 AM
71scgc's Avatar
71scgc
Cool Bike!!
Old Sep 24, 2011 | 09:17 AM
Tim H's Avatar
Tim H
Iv'e been running around town all week with open headers and the car runs great!!!!
Old Sep 24, 2011 | 09:37 AM
noonie's Avatar
noonie
Those had gobs of torque. Got one when they first came out, metallic grey colored.
Memory is failing I don't think mine had lights.
Old Sep 24, 2011 | 10:51 AM
BKbroiler's Avatar
BKbroiler
I'm not surprised.
Old Sep 24, 2011 | 11:06 AM
billla's Avatar
billla
St. Jude Donor '14
Always an interesting discussion I was on another board where someone expounded on the virtue of small exhaust pipes, even noting that he couldn't wait to prove everyone wrong by making more power with 1.5" exhaust! While exhaust velocity is the key...the impact of larger pipes is overstated once you move outside of the header and about 18" back from the collectors. I found this article to be good reading:
http://www.hotrod.com/techarticles/e...tem/index.html
"In theory, the larger the engine's displacement and the higher the rpm where peak horsepower occurs, the better it should respond to the reduced backpressure of a larger-diameter exhaust. Conversely, it's been said that a mild engine with too much exhaust flow may fall on its face with not enough backpressure, though we've never seen that to be true and can't even imagine how backpressure could help performance in a four-stroke engine.
...it came as no great surprise that our test revealed more power everywhere with the 3-inch system compared to the 2.5-inch system."
Old Sep 24, 2011 | 11:38 AM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
That is a very good explanation, the H or X pipe does the same thing as an exhaust pulse from one bank will help pull the next exhaust pulse from the other side because the crossover pipe connects the two sides.
I have have had experience with this so called "backpressure" and when you think about it do you really want something blocking the exhaust route. Ever see mufflers on Top Fuel Dragster, no, they are open and they look simple but they are tuned to the 10,000RPM the motor turns when it goes down the track. Actually easier than tuning our own exhausts. The TFD starts at 10,00RPM and ends 10,000RPM via a multiple clutch disc setup. So once they find the exhaust size and length they are happy with they are done.
The explanation above is very good as it discusses low end power loss and this is a result of not having the correct size pipe for the RPM range. At 2000RPM it will feel like it has more torque, put it on a dyno and you may very well see a bit more torque down in the low RPM range but you will lose power once you get into the cam's power range and overall average power will be down with an exhaust that is too small.
The Top Fuel Dragster or circle track cars are actually easier to tune the exhaust too because of the narrow RPM band they run in.
We have to find the correct size headers, exhaust pipes and mufflers for a huge RPM range of say 1500RPM to 7000RPM and it really can't be done without extensive testing of different size tubes and mufflers.
One thing is for sure if you feel more torque with a certain smaller muffler or pipe at 2000RPM it is not going to give you as much overall power as a bigger pipe or muffler that doesn't feel as "torquey" at 2000 RPM. It is a balancing act and most of us are just guessing and as stated above getting confused. None of us have the time and money to get the perfect exhaust for such a large RPM range, you can get close though
Old Sep 24, 2011 | 02:52 PM
gcusmano74's Avatar
gcusmano74
The factory tunes the engine to run well with the amount of backpressure in the stock exhaust. If you make the exhaust less restrictive, the engine may need to be retuned to match the new setup, to produce all the power it is capable of. Until you do that, the engine might not make any more power than before.
As far as smaller pipes making more power, they are talking about the 4 primary pipes in each header. For street cars. Once you are past the end of the collector, you want to minimize backpressure. And that generally means bigger pipes and free flowing mufflers.
An engine basically is an air/fuel pump. Anything you can do to make the engine process more air and fuel in a given amount of time will allow the engine will make more power. You can improve that situation with 1)more RPM, 2) more displacement, or 3)less restrictions to the flow.
Old Sep 24, 2011 | 06:42 PM
scottyp99's Avatar
scottyp99
Yeah, I've always heard the old saw about "The engine was designed to operate with backpressure, if there's not enough backpressure it'll lose power" and it never made any sense to me. I always figured it was just guys who put a set of headers on and didn't re-jet the carb, so now it's running lean. Never really thought about larger primaries moving the rpm range up. Interesting!!
Scott
Old Sep 25, 2011 | 12:43 PM
81pilot's Avatar
81pilot
Scott
Most stock cams don't have much valve overlap so rejetting with pipes and headers as the only addition is not always neccessary, and sometimes counter productive.
Old Sep 25, 2011 | 03:35 PM
scottyp99's Avatar
scottyp99
Originally Posted by 81pilot
Most stock cams don't have much if any valve overlap so rejetting with pipes and headers as the only addition is not always neccessary, and sometimes counter productive.
Oh, right!! Both valves have to be open at the same time for long enough for the scavenging action to actually pull the intake charge in, something like that anyway.
Scott
Old Sep 25, 2011 | 03:49 PM
billla's Avatar
billla
St. Jude Donor '14
There is always at least a bit of overlap to ensure the escaping exhaust pulls the intake charge (scavenging) and that the exhaust valve gets a bit of cooling from that incoming charge.
The formula for overlap is Exhaust Closing + Intake Opening, so even on a mild cam there's around 20-50 degrees of overlap.
Old Sep 25, 2011 | 08:42 PM
81pilot's Avatar
81pilot
That is not much.....The escaping gas creates a low pressure gradient allowing the intake charge to enter faster on the intial surge I understand that. I mispoke, there is always some, but 20 degrees ain't much :O)
Old Sep 25, 2011 | 11:35 PM
Little Mouse's Avatar
Little Mouse
i need one of these what yrs did they make them. Or simular sized yamaha's before the really long travel suspension started showing up.
To Backpressure?
