Strut Rod Setting
Old Sep 24, 2011 | 08:18 PM
ted13b's Avatar
ted13b
Default Strut Rod Setting
I've just replaced my bent right rear strut rod. (The bushings were shot anyway!) Any suggestion for the alignment seting till I can get it to a shop for a eal alignment?
Old Sep 24, 2011 | 08:26 PM
'75's Avatar
'75
Use a piece of lumber(2x2 or 2x4) cut it to fit inside the outer lip of the wheel. Hold the lumber vertical against the wheel then hold a level vertical on the lumber. The wheel should lean in at the top 0 - 1/8". This is to be checked after the car is on the ground and rolled back and forth in and out of the garage to settle the rear suspension. No need for an alignment.
PS, make sure the car is on a level surface
Old Sep 24, 2011 | 08:27 PM
Ganey's Avatar
Ganey
It's possible to set it at straight up vertical by eye or w/ a level.
Old Sep 24, 2011 | 08:39 PM
gcusmano74's Avatar
gcusmano74
Start out in a nice level space.
Turns out that if you take the measurements 14 3/8" apart, 1/4" exactly equals one degree. So you have a 15" wheel. Close enough. Get a small level. If you set the camber so that the rear wheel tips in at the top by 1/8", you will have set the rear wheel camber to 1/2 degree negative.
A significant change in rear camber will affect the ride height. Sometimes you need to go back and forth to get everything dead nuts.
Old Sep 25, 2011 | 10:32 AM
terry82's Avatar
terry82
i had mine done at a shop. there is a half a inch or more differance between the top of the tire to the bottom .is this off?
Old Sep 25, 2011 | 06:18 PM
ted13b's Avatar
ted13b
Mine are both at 1/2" now, I guess I have some adjusting to do...
Old Sep 26, 2011 | 09:13 AM
gcusmano74's Avatar
gcusmano74
Starting from a level floor, assuming you are measuring 1/2" in at the wheel, then your camber setting is 2 degrees negative! Ouch!
You will burn off the insides of both rear tires in not too many miles.
Old Sep 27, 2011 | 12:12 PM
ted13b's Avatar
ted13b
I have a level which I'm putting vertically against the sidewall of the tire. If it's touching the lower sidewall, the level is 1/2" out from the upper sidewall.
Old Sep 27, 2011 | 12:16 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
The level should be placed on the upper and lower parts of the rim, not the tire. If your level is too long, cut a 2X4 piece of wood and attach it to the level so that it fits on the rim only.
Old Sep 27, 2011 | 01:11 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Bingo. Eyeball it exactly long enough to drive to the alignment shop.
Old Sep 27, 2011 | 02:19 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Originally Posted by Jud Chapin
The level should be placed on the upper and lower parts of the rim, not the tire...
If you do put the level against the sidewall, at least make certain to avoid the buldge above the contact patch.
To Strut Rod Setting
