1981 Tachometer
Old Sep 24, 2011 | 08:45 PM
sabre1981's Avatar
sabre1981
Default 1981 Tachometer
I searched the forums and I'm thinking my answer won't be what I want, but I want to make sure. I just dumped the stock distributor and installed a vacuum ported one. Now I have no tachometer, so is installing an older (non-electric) tachometer the only way to get it working again?
Old Sep 24, 2011 | 08:53 PM
Ganey's Avatar
Ganey
No. If you put in a HEI, check that you have the tach wire to dist. connected.
Old Sep 24, 2011 | 11:14 PM
sabre1981's Avatar
sabre1981
99% sure it was HEI, is this not the tachometer wire? There is no place I see for this wire to come out of the inside of the distributor. A friend who was helping me hooked the distributor back up so at the moment I am unsure if there is another wire left off.
Old Sep 25, 2011 | 12:20 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
It should have a pulse wire on it.. what is the distributor out of?
Old Sep 25, 2011 | 07:49 PM
sabre1981's Avatar
sabre1981
The distributor is brand new, but I talked to a friend and think I now understand what is being said. I need to take the tach wire from the 4 wire packard and run it to the distributor? If this is right, then my follow up questions are which color wire is for the tach and to which wire does it need to be put to on the distributor?
Old Sep 25, 2011 | 09:52 PM
0Willcox Corvette
Former Vendor
What is the distributor out of.. If I have a schematic I can look and see which wire is the tach wire.
Old Sep 25, 2011 | 11:02 PM
sabre1981's Avatar
sabre1981
The old one came out of a 1981 350. When you asked the first time, I just thought you were asking about the new one thinking it was used, sorry.
Old Sep 26, 2011 | 10:40 AM
0Willcox Corvette
Former Vendor
On a 81 the signal wire should be white.
Old Sep 26, 2011 | 12:52 PM
wajulia's Avatar
wajulia
The cable you have in the picture if the computer control connector for the 1981 and will not be used in the new Distributor.
I believe that the tac connector was the red connector that you removed and I saw in the pictures you showed me of the relay. If that is true, you can keep the red connectors.
Old Oct 1, 2011 | 08:57 AM
sabre1981's Avatar
sabre1981
OK, it works now
To 1981 Tachometer
