Electrical...please help
Old May 2, 2002 | 03:44 PM
kjsmarty's Avatar
kjsmarty
Default Electrical...please help
A wierd situation occurred driving this week. Car is a '78. Alternator light came on and lost all gauges. Alternator bench checked...fine. Battery bench checked at Sears (under warranty)...fine. Replaced belts. Light still on, gauges dead, battery loses charge. All fuses O.K. Needless to say I'm lost!!! Any help would be greatly appreciated. Thanks
Old May 2, 2002 | 04:59 PM
Prufrock17's Avatar
Prufrock17
Default Re: Electrical...please help (kjsmarty)
Check your fusable link. I had the same prob in my 78 and it turned out to be a bad fusable link. Also make sure all of your wires are connected properly and nothing is grounding out.
Old May 2, 2002 | 05:04 PM
Darkness's Avatar
Darkness
You most certainly have a "short" circuit, maybe some old wire melt enough to expose the core and now is tuching ground. Your local shop should be able to find the prob. :cheers:
Old May 2, 2002 | 08:14 PM
Pete79L82's Avatar
Pete79L82
There are two fusible links by the starter. Each feeds power to some parts of the car. It sounds like the the one that goes to the altenator is bad so the altenator cannot feed current back to the battery.
Old May 3, 2002 | 12:55 AM
Rockn-Roll's Avatar
Rockn-Roll
Check for a loose ground...there is a major ground terminal where about a dozen system use as a grounding strip under the front of the center console. You will need to move the center console back anyway if you are to inspect the gauges.
Old May 3, 2002 | 01:12 PM
kjsmarty's Avatar
kjsmarty
I really appreciate the help...but I haven't had elctrical 101 yet. What is a fusible link and where is it? Thanks again.
Old May 3, 2002 | 01:18 PM
One GM A Tech's Avatar
One GM A Tech
look by the starter :seeya
Old May 3, 2002 | 02:14 PM
JB's Avatar
JB
St. Jude Contributor
This is one of those deals where a picture is worth a thousand words. But my danged digital camera has bitten the big one. If I were you, I'd get a repair manual (like Chilton's), because they'll probably have pics.
The short answer, though, is that fusible links are sections of wire that are designed to fail--they're of a smaller gauge than the wire they're connected to, so they burn instead of the wire (or a significant portion of your harness). They have extra thick insulation, so they'll look fatter than the wire they're in circut with.
JB
To Electrical...please help
