the 6 litre LS and trans deal fell through so i'm now looking at doing a manual trans conversion kit http://www.summitracing.com/parts/CMG-17X-600-6-X/ and the one question i have is, do i have to put on a different trans yoke. i figure it has to be shortened but other than that it seems pretty straight forward. this will be going behind the GMPP 290BHP/326 FT LB crate motor. i will not be abusing the trans. no side stepping the clutch at 6k RPM's no drag racing, i just want a decent reliable daily driver and i'm going to work at it to get the best mileage i can when on my regular 1800 mile round trip jaunts from Columbia SC to Windsor CT.
I think that is the manual to manual conversion kit. I am wanting to do the same in mid November. I also think the Summit kit does not come with the driveshaft, check that out before you buy.
thank you very much! this will be a huge help for me. a question now. does anyone think that a T-5 would live behind a 290bhp, 326 FT LB motor? I have a T-5 from a 90's Trans Am, all it needs is a rebuild and i have the parts already. if not, i've been offered a good price for it.
thank you very much! this will be a huge help for me. a question now. does anyone think that a T-5 would live behind a 290bhp, 326 FT LB motor? I have a T-5 from a 90's Trans Am, all it needs is a rebuild and i have the parts already. if not, I've been offered a good price for it.
For your intended type of driving a T-5 would be a great choice IMO. I have one behind a 400 hp SB and only jump on it from time to time and it has held up well for over 10,000 miles. I get 25 mpg on the highway at 70 mph turning 1900 rpm's and can light 'em up outta' the hole with a squeal in 2nd and a chirp in 3rd.
The real weakness in a WC T-5 is if you power shift 2nd. to 3rd.
I did mine with a WC T-5 out of a '92 Ford with a adapter plate for about $700.00.
Good Luck!
very cool. i got the rebuild kit and the steel throwout bearing retainer a few years ago and it's just been sitting in my shop ever since. i knew i was holding on to the thing for a good reason.
Wow. I can do that same exact kit for $3499 shipped WITH A DRIVESHAFT and 36 month product warranty.
