Trailing arms & thrust
Old Sep 27, 2011 | 02:53 PM
RobbSalzmann's Avatar
RobbSalzmann
St. Jude Donor '12
Default Trailing arms & thrust How does it work?
Ok, I just finished replacing my trailing arm assemblies with all new stuff. As I was installing everything, a thought occurred to me.
It appears that the only thing bearing the thrust that the rear wheels generate to propel the car is the long skinny bolt that goes through the trailing arm bushing. I must be missing something here?
Old Sep 27, 2011 | 08:30 PM
RobbSalzmann
St. Jude Donor '12
Anybody?
Old Sep 27, 2011 | 08:40 PM
'75's Avatar
'75
That's it.
Old Sep 27, 2011 | 08:47 PM
birdsmith's Avatar
birdsmith
Ditto. Go to ultimatecarpage.com and look at the rearend of some Can-Am cars-upwards of 800 horsepower transmitted into the chassis tub by four little bolts...
Old Sep 27, 2011 | 08:56 PM
Mike Ward's Avatar
Mike Ward
Yup, that's it. Wanna see how big (small) the bolts are that hold engines on airplanes?
Old Sep 27, 2011 | 10:33 PM
my 76 ray's Avatar
my 76 ray
And three little bitty bolts connect the flexplate to the torque converter. They take 400+ horsepower in a lot of cars.
Old Sep 28, 2011 | 12:30 AM
gkull's Avatar
gkull
Your big thing is setting the rear toe in. I set mine for 1/16th per side for a total of 1/8th Some people go for more like a 1/4 inch total for less agressive driving
Old Sep 28, 2011 | 12:42 AM
Ben Lurkin's Avatar
Ben Lurkin
St. Jude Donor '09
Shear Capacity of a 1/2" grade 8 bolt (I think that's the size of that bolt) is somewhere approaching 18,000 lbf. The trailing arm mount configuration is a double shear connection so between both left and right trailing arms, you have 72,000 pounds of carrying capacity. I think you're probably safe. Not even 427Hotrod or 632C2 will be able to break those.
Old Sep 28, 2011 | 11:42 AM
RobbSalzmann
St. Jude Donor '12
Thanks for the explanation guys. It makes sense when you think about it in terms of shear strength of the bolts x4 (2/side). A measly blown 406 is no match for those four little bolts.
To Trailing arms & thrust
