My vette is 75 with air.If i drive 65 mph on the highway for approx 60 miles or more temp starts to climb slowly.It has gone to about 230 degrees.When i drop speed down to around 55 mph temp drops also.Drops to around 200.This only happens when air temp is above 70.I can drive around town in stop and go traffic without any problems-will run about 180 degrees. I have installed new GM radiator changed thermostat from 190 to 160 new belts and hoses.Would like to drive my car to Forum cruise but dont know how high temp would go.I only drive car locally because of this.
Check your fan clutch...or get rid of it! Mine was bad -- it got replaced along with much of the A/C system.
In 95 degree weather (what we currently have in the afternoons), my '79 runs about 220 degrees on the freeway. At stoplights, it will climb a little, but goes away when I get going. With the A/C off, she cools down some, but I heat up!
I think this is about the normal operating condition for this car!
It may not be a cooling system problem. It may be the ignition timing. It may not be advancing far enough or not at all. Retarded timing will make an engine run hot. Obviously the higher the RPM the worse that would be. Make sure that the advance portion of the distributor moves. Sometimes the cener shaft gets frozen and the wieghts will not advance the timing. Also check the vacuum advance and related hoses. Check for a plugged catalytic converter also. This will cause overheating big time! :cool:
I went through heel with my vette a few week ago with temp going up to 250F on the hyw and running at 200F in the city, Here is what I did to solve the problem.
1-Get the rad cleaned at a rad shop and do not paint the fins with any paint just leave the black primer the rad shop adds. Most guys like to see their rad look shiny and paint the core and that is a killer
2- install the seals around the rad water pipe insulation works great
3- I removed the elec fans and re-installed the stock rad fan
4- replaced the crazy comp 292h cam with a Crane 272 cam
The 454 is running at 160F with a 160 stat at any speed with the air on, I may have to go upto a 180 stat currently running to cold.
This is some very good advice. The idea of dropping the fan clutch is off base however. The fan clutch is designed to bring more air into the front of the radiator. If going 65 mph down the road doesn't put enough air through the radiator then nothing will. These clutches are designed to work best in the city and at slower speeds. Theoretically speaking, you could drive your car all day long on the highway with a fan or clutch. The biggest problem in cooling is often insufficient cooling capacity such as you might experience with an older radiator. We just drove with a 34000 mile 77 from Pittsburgh to Asheville, NC and the car started heating up going up hill. The radiator had a very noticable temperature differnence from top to bottom. The bottom was actually cool to the touch! :eek: This car had sat for a number of years and we suspected that the silicates in the antifreeze had precipitated out into the bottom of the radiator. Once you get your radiator cleaned up and perhaps rodded out, you will notice a big difference in the cooling capacity. Check for excessive paint on the fins, debris and dirt around the fins and a marked temperature difference from the top to the bottom of the radiator.
Gary
I hope you don't have the same problem that I did. My vette was overheating real bad, and for some reason the brakes felt like they were locking up, though they freed up as soon as I pulled off the highway. I finally broke a spindle and upon inspection found that the rear wheel bearings were running without sufficient grease...too much friction was causing excessive drag and thus causing the engine to work harder and overheat. Anyway to make a long story short, all that was done was control arms were rebuilt and now I can cruise at 70 with air conditioning running in 80degree weather and the coolant maxes at 205.
I had the same problem in my 4Runner, and only solved it by replacing the radiator (after replacing EVERYTHING else first :mad ). I don't necessarily understand all the thermodynamics involved, but a brand new water pump and four radiator flushes had no effect. I bought a new radiator and dropped it in and have had no problems since then. Hope this helps. I know that a hi-tech engine like the 4Runner automatically adjusts timing, etc, so those can't be ruled out on your Vette, but if all else fails it may be that the radiator isn't flowing to capacity.
