Help Me Identify This Plug
Hi
I am fitting a new engine wiring harness to my 71 with Auto and a/c.
On the drivers side between the power booster and wiper motor are mounted the 2 CEC relays but there is also another plug that comes out of the harness at the same point.
The one I am trying to identity has an orange and a tan wire going into the plug.
Craig
Craig
Former Vendor
Received 1,816 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
You un-pin them.. if you look at the terminal on the inside.. you'll see a section sticking upward. This is what holds the terminal in the plastic connector. Take a small thin screw driver and push inward and it will release.
I have a pic of this somewhere.. hold on. I can't find it.. I'll keep looking.
Former Vendor
OK.. remembered where it was at.. go to this link..
http://willcoxcorvette.com/repairand...lp.php?hID=313
Ignore what it says its for and click on supporting document.
Once open go to page 8 and you'll see instructions on how to un-pin the wire from the connector... Real easy..
