Please confirm alternator diagnosis
Old Sep 29, 2011 | 04:36 PM
Sean82's Avatar
Sean82
Default Please confirm alternator diagnosis
I have had a recent battery drain.
Removed fuses – drain remained
Disconnect red wire from alternator – drain eliminated
Rebuild my alternator, new voltage regulator brushes etc.
Reinstall alternator – drain reappears – much less 2.5amps
Disconnect alternator – drain eliminated.
Test for continuity from car ground to red wire at alternator – none
Test for continuity at alternator red post to ground – none
My only guess is the windings are bad on my alternator. Any others things I am missing?
Old Sep 29, 2011 | 04:50 PM
djrammer's Avatar
djrammer
Bad diode in the alternator.
Old Sep 29, 2011 | 05:46 PM
Sean82's Avatar
Sean82
nice.
where do i get the diods?
My alternator rebuild kit did not have them
Old Sep 29, 2011 | 06:54 PM
Ironcross's Avatar
Ironcross
Auto parts store in your area.....
Old Sep 29, 2011 | 08:25 PM
...Roger...'s Avatar
...Roger...
http://www.autozone.com/autozone/par...mString=search
Old Sep 30, 2011 | 05:06 PM
Sean82's Avatar
Sean82
it is also called a bridge rectifier
= a bunch of diodes and a heat sink.
Old Sep 30, 2011 | 05:32 PM
...Roger...
yep and the other is a diode trio
Old Oct 1, 2011 | 08:22 AM
Hef's Avatar
Hef
The bridge rectifier makes sense as the problem (diodes) as they take the AC sinusoidal voltage (created by the alternator windings) and rectify one half of the sinewave, + DC Voltage out.
This output sill has to be regulated to maintain 14 V approximately by the voltage regulator.
The bridge rectifier diodes could become leaky over time, and allow current from the battery to flow to ground thruogh the diodes. A good diode will not conduct current in this direction due to the polarity. (+ battery/-cathode on diode)
Hef
To Please confirm alternator diagnosis
