1970 brakes need help
If it tells you anything, I used to have to bleed my calipers once a month and eventually once a week - before I finally got fed up and replaced them with the O-ring design. If you already have stainless-steel sleeved calipers, you can buy just the O-ring piston kits and save a lot of money.
It has been said (by smarter people than me) that o-ring pistons simply mask the true problem, which in many cases is air pumping either by out of spec rear rotors or poorly adjusted (or just worn out) rear wheel bearings. I honestly don`t think the problem is the "lip seal" but the corrosion on the pistons under the seal. ...redvetracr
Still, the O-ring design may be a "mask" as you say (and I don't argue that either) but it does work, and quite well. I feel it's far superior to the original lip seal design. Also, as far as corrosion, you'll notice that all O-ring setups have stainless-steel sleeved calipers to prevent that.
If anything, Autozone sells stainless-steel-sleeved calipers with the original lip-seals in them for $80 a piece, but for that kind of money could get the O-ring ones from Vette Brakes (although you'd have to send in a core to Vette Brakes and wait for the return, as where you can drop your cores off at Autozone.)
If you *REALLY* want to do it right, get your rotors turned and then put a dial indicator on them to make sure the runout (in place, on the car!) is very low. Shim the studs. This is a very tedious task and I'm not sure how worth it, it is.
1. Get a magnetic dial indicator and check the rotor runout on all 4 wheels. Turn the rotor slowly and watch the indicator. If runout is more than spec you will always have a problem getting a bleed that holds. You will get a hard peddle but it will pump air as soon as you start using running.
2. On a new MC, bench bleed it slow slow slow or you are aerating bubbles internaly. When you put it back on check the rod length from the booster if you power brakes. You shoud have about 3/4" free travel before you contact the MC piston. If not adjust it. Just because it worked with an old one does not mean the pistons are the same and rod length will be affected.
3. Did you use silicon or Dot 5 fluid. Frankly you will not get a hard peddle with silicon.
4. New calipers if they are not leaking should be ok, if all else is ok.
4. Read the posts and the book on bleeding methods and sequence. You might want to consider a power bleed also.
Good luck on this common vette problem.
I can't totally agree with #3. I can only speak from my own experience.
I converted to silicone fluid over 10 years ago. I have a very firm peddle.
No problems at all since I went to DOT5.
Some people have had difficulties using silicone fluid. I don't know what makes one vette work well with DOT5 and others do not.
Barry
Wish I knew the secret of silicon fluid vs regular. I used silicon with all new calipers and the peddle was ok, but when it was hot out it seemed to fade and get a little spongy. I flushed the silicon out and put in new regular fluid, bled it out and had a very firm peddle - what I guess you expect GM power brakes to feel like. No other changes.
When you did your brakes with DOT5, did you rebuild the master cylinder as well??
I rebuilt mine when I replaced the calipers.
Just wondering if maybe the M/C is not in good shape, then the DOT5 may not come up to pressure as quickly as DOT3.
From past posts here on the Forum, looks like a rebuilt unit could be far from perfect.
We may never know.
Barry
When I installed it, I rebuilt the master cylinder and installed SS sleeved calipers.
The fluid itself has remained perfectly clear, and has outlasted 3 sets of caliper seals.
RE redvetracr.... he is right about the area where the outer dust seal rides. This is the first line of defense, and it is where aluminum pistons always fail. I use SS pistons to avoid this problem.
Silicone fluid, stainless pistons & ss sleeved calipers, and rotors with runout within spec have been a winning combo for me.
If the rotors are within spec, you don't need the special pistons/seals.
As posted, they only mask the real problem.
They are a great product, they work, but you don't need them if your runout is within spec.
In fact, they work so well, that the continuous pulsing of out-of-spec rotors causes the pistons to slam against the caliper bore/sleeve. egg-shaping it and eventually rendering the caliper useless.... before the seal leaks. They shouldn't be used as a repair for out-of-spec rotors, and the manufacturer will tell you that.
My 66 has been "in spec" since I bought it in 1975 and I have standard design (but stainless) pistons & seals..... and no problems.
My 70 is "in spec" as well... again... no problems with the brakes.
The inner seals will always go bad over time, no matter what type you buy.
Gary
Actually the MC was the origional. I replaced the calipers and flex lines, then used silicon. What you are saying has merit. An old one with margional seals or a rebuiild with margional seals could do the same. I think Silicon is a lesser viscosity than regular fluid and this may answer the question.
Jim
