Help Overheating with new engine ALSO
Old Oct 1, 2011 | 12:44 AM
zakim's Avatar
zakim
Default Help Overheating with new engine ALSO
I had a 21,000 mile crate engine that was over heating so I install a new Alum Radiator( 3 rows Champion), new fan clutch and seal up the shroud, new 185 thermostat and it was still over heating to 230 then I find out that I have a head small gasket leak so I got new rebuilt engine -- CHEVY 350 / 325 HP 4 BOLT HI PERF BALANCED CRATE ENGINE -- and now with the new engine, new fan clutch, with a new water pump and another new thermostat and new top hose it is still over heats to 225 when in idle with AC on ( I have a second thermostat direct water hook up on the passenger side ) WHAT HAVE I MISSED ? When driving with AC on it is at 195 just like it was with the old engine ! --- HELP HELP PLEASE !!!
Old Oct 1, 2011 | 04:48 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
Before you start missing with the cooling system, make sure that you have the correct air/fuel mixture and the correct ignition timing, these two things will cause your engine to overheat no matter how big is your cooling system.
