Which cam?
Old Oct 1, 2011 | 06:15 PM
obas's Avatar
obas
Default Which cam?
This is for 1975 Vette with 355 CI, 202 heads, roller rockers, headers/sidepipes, 700R4 tranny, custom torque convertor, 3:73 rear end, Mallory ignition, vacuum pump and AED Carb.
The goal is 400+ HP with maximum performance across the band and still be able to drive around town and take on 200+ mile trips.
Thinking about a Comp Cam 292H Series or an Edelbrock Rolling Thunder #2201.
http://www.jegs.com/i/Comp+Cams/249/12-213-3/10002/-1
http://www.edelbrock.com/automotive_...chevy_sb.shtml
Are these choices to aggresive? Recommendations?
Old Oct 1, 2011 | 06:53 PM
billla's Avatar
billla
St. Jude Donor '14
"202" heads usually refers to the intake valve size. What's the casting number on the heads, and what valve springs are installed?
What intake/carb?
Old Oct 1, 2011 | 07:08 PM
scottyp99's Avatar
scottyp99
Back in the day, I had a Roadrunner with a 440 in it. I used a 292 advertized duration, .505 lift cam in it, and it had a fairly "blucketa, blucketa, blucketa, bluck, bluck-bluck, bluck-bluck, bluck-blucketa, blucketa" kind of idle. I would think a cam like that in a 350 would have a pretty radical idle.
LOL! I just proofread my post and laughed my *** off!!
Scott
Old Oct 1, 2011 | 07:09 PM
billla's Avatar
billla
St. Jude Donor '14
To fix LMAO, I suggest a Loctite two-part epoxy with a 15 minute set time. A jig may be required to ensure the bifurcated cheeks are appropriately vertically aligned.
To Which cam?
