which shocks with composite rear poll....
Old May 3, 2002 | 05:04 AM
razz1980's Avatar
razz1980
Default which shocks with composite rear poll....
so many opinion so lets get a final answer..keep in mind the best for the PRICE ..not just the BEST...and this is for a vette with a rear fiberglass spring not the steel leaf spring..
Old May 3, 2002 | 08:18 AM
jsimpson's Avatar
jsimpson
Default Re: which shocks with composite rear poll.... (razz1980)
Thirty years ago. I'd have voted for Koni. Times change; Bilsteins have transformed both my Tundra and my one ton Dodge RAM. They do what no other shock comes close to doing!
Old May 3, 2002 | 08:38 AM
CharlieF's Avatar
CharlieF
I have Bilstiens also.........I had a set on my old camaro and they worked great even with over 85Kmiles logged on them
Old May 3, 2002 | 11:31 AM
vettesite's Avatar
vettesite
I've got the VB KYB GR-2s front and back. They are a good all around shock for the street that works well with a glass spring. Smooth over the bumps and ok around the turns. I wouldn't get them if you want a serious performance shock.
Old May 3, 2002 | 01:24 PM
MIKER's Avatar
MIKER
I added "Tokico" to the list. I'm curious to see if any other forum members are using them. http://www.tokicogasshocks.com/
Bilsteins are probably the most popular shock for used by forum members with composite springs so they must be good.
Old May 3, 2002 | 03:23 PM
DavidOrr's Avatar
DavidOrr
Default Re: which shocks with composite rear poll.... (vettesite)
Old May 3, 2002 | 05:50 PM
Stingy74's Avatar
Stingy74
Default Re: which shocks with composite rear poll.... (DavidOrr)
GM made a shock that works almost perfect. It nearly eliminated the good compression/fast rebound personality that alot of the monosprings out there have. The number is 4993538 but I have been told that it is now discontinued. I don't know who came up with the number, if they are Corvette specific, or any shock rates or anything but someone did their homework and found these shocks that actually work. If you can find them, buy 'em!
To which shocks with composite rear poll....
