Reverse shifter
Old Oct 3, 2011 | 10:47 PM
lhcorvette's Avatar
lhcorvette
Default Reverse shifter
Greetings!! my friends 1969 corvette reverse shifter is not locking. Instead goes right into reverse without unlocking the reverse lever. Can anyone please help us to why this is occuring? ( gears 1-4) are shifting nice, so its not the clutch. Thanks in advance
Old Oct 4, 2011 | 12:53 AM
DRIVESHAFT's Avatar
DRIVESHAFT
If the reverse lockout isnt working its a shifter issue.
Have you or your friend unscrewed the shifter ball and taken a look at whats inside?
If the pin in the center of the shifter handle is missing or broken, then the reverse lockout wouldnt work.
Old Oct 4, 2011 | 01:14 AM
lhcorvette's Avatar
lhcorvette
The reverse lockout does work, the spring is there. He even got a new one, and replaced it, but the problem still continues. Thanks Driveshaft!
Old Oct 4, 2011 | 07:30 AM
Phil Zell's Avatar
Phil Zell
Is the shifter factory ? or a Hurst, reverse lockout on the Hurst factory style shifter does not work, it is only there for looks.
Old Oct 4, 2011 | 11:52 AM
lhcorvette's Avatar
lhcorvette
No, It's factory
Old Oct 4, 2011 | 11:59 AM
MelWff's Avatar
MelWff
He got a new spring or the complete assembly below?
http://www.ecklerscorvette.com/corve...1968-1976.html
Old Oct 4, 2011 | 12:11 PM
...Roger...'s Avatar
...Roger...
The lockout rod will work without the spring,sounds like the rod might not be long enough.
Old Oct 4, 2011 | 08:22 PM
Hammerhead Fred's Avatar
Hammerhead Fred
Is the spring installed correctly?
I goes on top and pushes the lockout rod down.
If the rod doesn't reach bottom it won't prevent the shifter from moving through the reverse lockout gate.
Old Oct 4, 2011 | 09:32 PM
scottyp99's Avatar
scottyp99
Whenever people ask this type of question I.E. "My (fill in the blank) doesn't work, how do I fix it?" The first thing I always ask is: did it ever work, in your experience? Or has it always not worked, since you got the car?
Scott
Old Oct 4, 2011 | 10:13 PM
lhcorvette's Avatar
lhcorvette
It was the rod, J&D gave it to me to short! Thanks a ton guys, my buddy's mechanic was going to take out the entire shifting system, and you guys saved him a few hundred bucks ( those of you who actually helped me). Who would have known something so simple can cause so much disfunction,
Old Oct 4, 2011 | 10:17 PM
scottyp99's Avatar
scottyp99
It was the rod, J&D gave it to me to short! Thanks a ton guys, my buddy's mechanic was going to take out the entire shifting system, and you guys saved him a few hundred bucks! Who would have known something so simple can cause so much disfunction,
Nice!! I love happy endings!
.......And so, Prince Charming fixed his shifter, and didn't get soaked by the mechanic, and they all lived happily ever after. The end.
Scott
To Reverse shifter
