New Toy
Old Oct 4, 2011 | 06:12 PM
HBZ_81_C3's Avatar
HBZ_81_C3
Default New Toy
Think this will shoe horn in the C3?
Old Oct 4, 2011 | 06:32 PM
worship79's Avatar
worship79
Looks impressive! Got specs?
Old Oct 4, 2011 | 07:14 PM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Me likes
Old Oct 4, 2011 | 07:16 PM
7t9l82's Avatar
7t9l82
it will bolt in , a dry sump system tank would be fun to have in there too.
Old Oct 4, 2011 | 08:16 PM
oldsarge's Avatar
oldsarge
Looks like it will go in alright, just hope that it stays put.....
That looks like you are going to have a little power under that hood.
Old Oct 4, 2011 | 09:13 PM
HBZ_81_C3's Avatar
HBZ_81_C3
It's a 518 CID Schmidt with Profiler Hitman heads with 1 small kit.
Old Oct 4, 2011 | 10:38 PM
ajrothm's Avatar
ajrothm
Damn...
That going in the 81'?
That oughta be good for what, about 800hp on motor? Another 250 on the fogger?
Top secret I'm sure...
You'll really be testing the aluminum IRS now... lol
Old Oct 4, 2011 | 10:50 PM
HBZ_81_C3's Avatar
HBZ_81_C3
Originally Posted by ajrothm
Damn...
You're close... 2.8hp per cube on the dyno at Schmidt's.
Old Oct 4, 2011 | 10:58 PM
ajrothm's Avatar
ajrothm
2.8 per cube on the motor alone? holy $hit.... That's a pro stocker right there.....lol
Damn good power even if that's on the jug....
My guess would be 800-900 on motor and 300-400 on the fogger. Either way that is high 7 sec power in the right chasis....like a 10.5...
I hate to know what that baby set you back.
A buddy of mine recently did a short deck "454" from Naiser. Sheetmetal single dominator, painted big chiefs....made 1050hp with the nitrous tune up. Got a fogger and a plate. It's going in a 69 camaro 10.5w. The motor before he built it was in a 63 split window street car that went 7.80s on one small kit...with about 200hp less at the crank..... And drove it to car shows on the weekends...lol
Old Oct 5, 2011 | 02:51 AM
7T1vette's Avatar
7T1vette
Only if the frame/suspension has been upgraded with super-duper titanium unobtainium!!! That is a monster.....
Old Oct 5, 2011 | 07:01 AM
HBZ_81_C3's Avatar
HBZ_81_C3
This is not going in the Vette.
It's for our X275 Drag Radial car. Rules require a cast intake and with a big block we can only have one kit and also limited on max pill size 054. Limited to a 10.2 deck as well. The dyno results were with a .038 pill which leaves us plenty of room to step it up if needed. Minimum weight for big block cars is 2450, so we are good there. Actually going to have to add about 150lbs. of ballast. This should be a ton of fun on a 275 tire. We're limited to 275/60X15 rear tire! Most of the races are 1/8 mile and we will need to be in the 4.90's or better to be competitive. We ran 5.08 @ 149 MPH with basically the same motor that was 522" that made less power. Schmidt found something with the 518 combo that really helped broaden the curve and made way more up stairs.
And, can't run wheelie bars either!
Old Oct 5, 2011 | 10:51 AM
7T1vette's Avatar
7T1vette
What clutch hardware do you use with that to manage all that torque without just making smoke?
Old Oct 5, 2011 | 03:31 PM
HBZ_81_C3's Avatar
HBZ_81_C3
No clutch. 5500RPM torque converter with a Powerglide and a lot of electronics to get it applied without blowing the tires away.
Old Oct 5, 2011 | 04:06 PM
ajrothm's Avatar
ajrothm
bad *** car right there.... Any other pics of it? The 275 class cars are AWESOME to watch.....very entertaining.... 4.90s on a 275 is just insane...... It was just a few years ago 10.5w cars were running 4.90s.....
Good stuff man...
Old Oct 5, 2011 | 09:00 PM
CFD E59's Avatar
CFD E59
I sure hope so. I would like to see video of that thing launching.
Old Oct 6, 2011 | 11:54 AM
HBZ_81_C3's Avatar
HBZ_81_C3
Good stuff man...
Got some pics... probably not appropriate on this forum.
I think the engine and tranny are the only forum appropriate pieces in the car.
Old Oct 6, 2011 | 12:03 PM
HBZ_81_C3's Avatar
HBZ_81_C3
The launch is really pretty sweet. The car rolls out rather soft for about 20 feet then we begin bringing the power in on a fairly rapid curve and it picks the front up about 12 to 14 inches and carries it to about 500 feet or so and gently sits down. We always trip the 60' and the 330' clocks with the rear tires which give us slow numbers there. Have on occasion hopped the MPH clocks and have had some 200+ MPH time slips for the 1/8 mile!
Old Oct 6, 2011 | 06:34 PM
RobbSalzmann's Avatar
RobbSalzmann
St. Jude Donor '12
If it wont fit in yours, I'm sure I could make some room in mine.. You know, just sayin'...
I'd love to know what all the electronics are.
To New Toy
