what about new Camshaft
My actual setup:
ZZ430
Horsepower: 430 @ 5800 RPM
Torque: 430 Ft. Lbs. @ 4000
Comp. Ratio: 9.6:1
Camshaft: LT4 HOT cam, hydraulic roller tappet
Lift: .525” I, .525” E; Duration @ .050: 218° I, 228° E
Centerline: 109° ATDC (After Top Dead Center) intake, 115° BTDC exhaust
Cylinder Heads: Fast Burn, aluminum,
23° valve angle, Valve Diameter (Intake/Exhaust): 2.00” / 1.55”, Chamber Volume: 62 cc
Rocker Arms: 12370839 GM 1.6:1 self aligning roller rockers
i would like tu go to ZZ465
Compression Ratio: 9.6:1
Horsepower: 465 @ 6200 RPM
Torque: 440 ft/lbs @ 4600 RPM
Cylinder Heads: Aluminum Fast Burn, 62cc
Rocker Arms: 1.6 Ratio, Roller Rockers
Valve Springs: 1.250 in. Diameter (i need to upgrade tocomp cams)
Camshaft: 234 / 242
Camshaft Lift (in.) I/E: 0.575 / 0.595
can you tell me about idle and how it will live (race beast engine or soft street engine)
Or have you a better set up (camshaft ,.....)
Ps: i have a manual tranny T56
to much cam for low compression motor. You should have about 10.5 to 1 for a cam tha thas that much duration.
