Questions about operating temps
I have contemplated taking out the thermostat and running it with out one and see if that helps at all, but I am wondering if there are any risks involved with that. A guy I work with has a 32 Ford with a Chevy 350 and says he has no problems at all running with out a thermostat.
I have also read the thread about the spring in the lower hose. As I inherited my 79 this summer, I don't know if that spring is in there or not. Is there an easy way to check with out taking the hose off and draining the cooling system?
So, to break down this novel, my questions are:
-At what temp should I be concerned?
-What are the risks of running with no thermostat?
-Is there an easy way to check if the spring is in the lower radiator hose?
Thanks in advance everyone.
To answer your questions, IMHO 220 deg is no problem. Again, you may find 220 on your gauge is really 210...nothing to worry about. As far as ruining cylinder heads, if you're not boiling at shutdown or running at redline temps for long periods, you should be fine.
There's no reason to run without a thermostat. What I was taught is that your engine is designed to work best at operating temperature (180 deg+). All of the different parts, with all of their different cross sections and materials, are sized to work together at those temps--including your oil--and the purpose of the thermostat is to get them to those temps as soon as possible, then open to allow the radiator to remove excess heat.
You will be able to feel the spring by squeezing the lower hose with your hand.
Based on your comment that she heats up on the highway, I would also fill the gaps in your radiator support or cowl, and check/set your engine timing according to the article in the tech FAQ sticky.
One thing that stands out with this is that the footwell gets pretty darn warm when it gets about 180+ on the gauge. Is there a way to help on that? Tired of my feet sweating...
If you live in a hot area you can run w/o a thermostat though you may need one in the winter. A better solution is a 180 thermostat or adding hole(s) to thermostat. Note that if stock is 195, running lower thermostat or none then carb heating, EFE may not go off.
Hot foot well
You can make sure the heater shut off is working. Note blower runs full time on Low speed. I changed Low to Off.
Generally speaking, a temp of 240 is cause for concern, and the system should be checked. Much above that and you will probably start to have problems.
The fact that your engine temps go up when you ask it to do more work is not a surprise. However, the fact that it raises 20-30 degrees just from running at highway speeds is not normal.
It would not hurt anything to change the T-stat. It could have a mechanical problem that is restricting flow (not fully opening). That would cause the engine to heat up with more work being done. Also, the radiator could be limed-up inside, which will reduce cooling efficiency considerably. If you haven't had the radiator cleaned (not "flushed") in some time, you might consider doing that with some Prestone [or other brand] 'radiator cleaner'. If you follow directions, it will clear and build-up from the inside of the fins.
There are other 'cooling efficiency' type of problems as well: foam seals around the radiator deteriorating or missing--this will cause cooling air to bypass the radiator instead of going through it; missing shroud housing or missing shroud extension--reduces the ability of the fan to draw air; collapsing lower radiator hose--usually found when a "hi volume" water pump is added to the system; missing front spoiler under the nose--air is not deflected UP into the radiator airpath; improperly functioning thermostatic clutch on the fan; wrong fan for the system; etc.
Look for the 'cooling efficiency' type problems first. Fix any of those and change the T-stat, then see how it behaves. If you still have problems, use the radiator cleaner.
P.S. If your engine timing is retarded from where it should be at highway speeds (2500 rpm and higher), your engine will run hotter, also. You could have a distributor problem with the mechanical advance system, such that it doesn't advance properly with increased rpm. Put a timing light on the engine and raise rpm up to about 3000 or so. The timing mark should smoothly increase throughout that range. It it stops increasing at 2000 rpm [or isn't working at all], that could cause your problem, too.
Thanks!
but leaves a little big of a gap around the edges. I have been working on closing those off. I will keep you guys updated.
I looked at the vendors here and thought they would sell them and I knew years ago Dewitts did but can find anything now. Google lower radiator hose spring and you can view a pic.
In another post I took this
"The best material to construct a spring out of is a length of thin diameter Bronze Welding wire, and coiling it around a pipe or rod for size."
Don't forget to bend the ends a bit more, so that the sharp ends cannot piece the hose from the inside.
Doesnt have to be pretty, just in there.
I have higher temps at highway speed also and am working to seal around the radiator. It will go up 20 degrees when I'm at 65mph.
