Clutch Help Needed...
Old Oct 10, 2011 | 12:40 PM
DO2G's Avatar
DO2G
Default Clutch Help Needed...
What size (inch?) clutch and spline came in a 78 with a M21 trans?
Old Oct 10, 2011 | 12:48 PM
MelWff's Avatar
MelWff
which engine? L82 or base? L82 appears to use 11 inch 26 spline, base appears to use 10.4 inch 10 spline.
Old Oct 10, 2011 | 05:52 PM
DO2G's Avatar
DO2G
L82
Old Oct 10, 2011 | 06:30 PM
Tim H's Avatar
Tim H
If you had the 10.4 could you change out the flywheel and then use the bigger clutch and pressure plate?
Old Oct 10, 2011 | 07:23 PM
tracdogg2's Avatar
tracdogg2
11" 26 spline. Last year for 10.4 was 1970
To Clutch Help Needed...
