Help with correct Spark Plugs
Old Oct 11, 2011 | 05:27 PM
jsera's Avatar
jsera
Default Help with correct Spark Plugs
My tuner recommended that I buy NGK #7 spark plugs. I am currently running stock chevy 350 AC's. ANyone have expereince with these? Part#? Recomendations? Gap? My specs are as follow:
1978 Corvette
Carb – O.E. Qjet #17058206 1298CHX
350 CID .030 4 Bolt Main
64 CC Heads 2.02 1.600 AFR
Hi Rev lifters – Roller Rockers to Factory Ratio
Intake – Edelbrock Performer Air GAP 2601
Headers – Dynomax Ceramic coated # 86008 1-5/8in tubes, 3in collector - oval port 1.8 x 1.5
Hydraulic Cam
Accel HEI
Old Oct 11, 2011 | 05:45 PM
Ironcross's Avatar
Ironcross
all spark plugs do the same job and your using the correct one now...as long as the heat range is correct....AC 45TS or its equivalent as long as the heads are stock and reguardless of the name of the plugs.....The 45TS is a tapered seat plug and may not fit the heads correctly....aftermarket heads do not always use the OE plug size.....but .035 is the best performance gap
Old Oct 11, 2011 | 07:17 PM
thegazman's Avatar
thegazman
Default thegazman
I tried the new e3 spark plugs with three electrodes in my 79, L-82, but removed them as they foul easily if you don't run your carb real lean.
Old Oct 12, 2011 | 08:11 AM
Phil Zell's Avatar
Phil Zell
If you are running AFR heads, there was a spec sheet included when they were new recommending which plug to use
Old Oct 12, 2011 | 10:50 AM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
NGK #7 plugs typically refers to the heat range. Not sure why your tuner would recomend them unless you are in the 600 hp range with high compression. For your average engine you would be looking for an NGK plug in the 4 to 5 heat range.
Old Oct 12, 2011 | 11:08 AM
MelWff's Avatar
MelWff
Did you check the AFR web site?
http://www.airflowresearch.com/sbc_faq.php
To Help with correct Spark Plugs
