140 MPH Seedometer Installed
Old May 3, 2002 | 09:33 PM
8T1-7T9 BIONIC VETTE's Avatar
Default 140 MPH Seedometer Installed
A while back my speedometer 85 MPH unit stopped working.....it fluttered for a while then all together stopped recording MPH.
Today we installed a new 140 MPH speedometer also inspected the cable from the transducer to the instrument,.....was in very good condition....Could my transducer be bad, (where to purchase??????) or the cable from the transducer to the trans be bad, or the gear in the trans?.....Will this ever end????:rolleyes: :seeya Cappy
Old May 3, 2002 | 10:38 PM
dman535's Avatar
dman535
Default Re: 140 MPH Seedometer Installed (8T1-7T9 BIONIC VETTE)
Cappy,
Its very possible that the transducer has failed. I don't use cruise on my car so I replaced the two cable setup with a single long cable. The Last Detail has transducers for about $70.
Old May 3, 2002 | 11:09 PM
Default Re: 140 MPH Seedometer Installed (dman535)
dman535,
I don't have the cruise control hooked up either.....so I can run a straight cable to the trans?????Where did you get yours?????and how hard is it to replace?????? :seeya Cappy
Old May 3, 2002 | 11:15 PM
PROSOUTH's Avatar
PROSOUTH
From: Manchester, Dead Center in the Middle of TN 25 miles to Jack Daniels,10 miles to Geo Dickle, and .8 mile from the Liquor Store at I-24 Exit 114
St. Jude Donor '05
Don't blow a bunch of money on a Corvette Transducer, Look for a Cutlass, Grand Prix, Monte Carlo or something in a junk yard that doesn't screem $$$$.
I can look it up but I believe these all fit according to Hollander's
JIM :seeya
Old May 3, 2002 | 11:19 PM
dman535's Avatar
dman535
AC Delco makes/sells all the cables for Corvettes. You can go into any auto parts store that sells AC Delco and order the cable. You want one for a 78-82 Auto, without cruise. My guess is its going to be about 72 inches long. You need to get underneath the car to dissconnect the speedo cable from the tranny and you need to get inside the car under the dash to disconnect the cable from the speedo. From there you just remove the old cable and replace it with the new and by pass the transducer. I left mine in place, its just not hooked up.
let me know if you have any other questions.
Old May 4, 2002 | 12:30 AM
Thanks for the info dman535,
Can you guess what I'll be doing tomorrow????? Aloha :seeya Cappy
Old May 4, 2002 | 12:32 AM
Default Re: 140 MPH Seedometer Installed (PROSOUTH)
PROSOUTH,
Thanks for the reply.....since I don't use the cruise control...I'll replace both cables and remove the transducer.....Going with the single long cable..Thanks again guys... :seeya Cappy
Old May 4, 2002 | 01:14 AM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Just a note -- most times a jumping speedo is blamed on a sticking cable.
If you have cruise control, blame the transducer.
Mine was jumping for a while and then went down to zero.
The transducer locked up tight and ripped the end of one of the cables right off !!
If you dont want cruise, do like they say above and just replace with 1 cable from the transmission to the speedo.
Old May 4, 2002 | 01:22 AM
Default Re: 140 MPH Seedometer Installed (BSeery)
Thanks BSeery,
Tomorrow I'll be shopping around for a single cable and remove the Transducer...."Aloha Ya All" cause we down South... :seeya Cappy
To 140 MPH Seedometer Installed
