removing a rear end cover help needed
Old Oct 14, 2011 | 09:30 PM
xpoc454's Avatar
xpoc454
Default removing a rear end cover help needed
Anyone have a suggestion on a safe way to remove a differential cover if the prior user glued it shut with gasket sealer?
If you have a gasket do you even need gasket sealer?
thanks for any help
dont want to crack or break it.
Old Oct 14, 2011 | 11:10 PM
Peterbuilt's Avatar
Peterbuilt
Is the differential still in the car?
Old Oct 14, 2011 | 11:26 PM
xpoc454's Avatar
xpoc454
yes still attached.
Old Oct 14, 2011 | 11:34 PM
Peterbuilt's Avatar
Peterbuilt
Default Then you have a fair amount of work ahead of you!
Several forum members have detailed instructions and pictures on how to do this, you might try the "Search" button until one of them sees your post.
Do you have an AIM or service manual?
Old Oct 15, 2011 | 12:10 AM
bluedawg's Avatar
bluedawg
If you are down to just the rtv holding it on try a small Sharp chisel & a hammer, lightly tap the chisel between the cover & the diff. On my 76 I can usually use the cross member to pull the cover.
Old Oct 15, 2011 | 12:53 AM
xpoc454's Avatar
xpoc454
Yes its just being held by rtv. I am trying to cautious, dont want to break anything while replacing the cover.
I can slam it with a sledge hammer and a chisel, just wasnt sure how much it would take to break he gask sealer without breaking the cover.
Old Oct 15, 2011 | 01:30 AM
Peterbuilt's Avatar
Peterbuilt
You can remove the differential from the cover but you can not remove the cover without removing the crossmember and spring (etc).
What is the problem with the cover?
To removing a rear end cover help needed
