please help with battery drain on 79L82
new battery and new alternator already tried unhooking interior bulbs which are on a timer key is off and no load is being used. I know its a short or ground problem or bad switch or relay. the radio security system power antenna and wiper curcuits should have been taken out of the equation when fuses were pulled. any thoughts would be appreciated.
also problem with overheating at idle or heavy accelearation if you keep
vette moving cools back down would you drill a hole in the thermostat or replace water pump first?
Describe how you have your meter hooked up.
After flushing and filling the radiator the vette isnt overheating right now although after squeezing top radiator hose i think the water pump is getting weak.
It is designed for the newer style fuses but a couple of jumper wires and it will work on most anything.
http://www.harborfreight.com/30-amp-...ter-67724.html
I also have a drain on my battery and just trying to find the time to do the work.
Hook this up between the battery and the battery cable.
Remove fuses one at a time until the drain stops.
That is the circuit that is draining your battery.
Start off with the windshield wiper circuit.
Ralph
