MSD Blaster 2 Coil Test
Old Apr 14, 2013 | 10:05 PM
Kim72's Avatar
Kim72
Default MSD Blaster 2 Coil Test
I'm looking for an ignition miss. In checking my coil I have readings as follows:
Primary side: 1.1 ohms
Secondary side: 4.65 K ohms
I've read readings should be .7 ohms (primary) & 4.7K ohms (secondary).
With this primary reading, is this coil suspect??
Old Apr 15, 2013 | 12:56 PM
MelWff's Avatar
MelWff
best bet would be to ask MSD but check this link
http://www.msdignition.com/forum/showthread.php?t=15763
Old Apr 15, 2013 | 08:09 PM
Kim72's Avatar
Kim72
I'm getting no reply there either.
Old Apr 15, 2013 | 08:19 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Does your ohmmeter read zero when the leads are shorted together? Do you know if your meter is accurate at that low of a resistance?
Is there a reason you're using this coil? Do you have an original coil you can plug in for an A-B comparison?
Old Apr 15, 2013 | 11:00 PM
Kim72's Avatar
Kim72
It's a good digital ohm meter. Yes, it zeros out. Just trying to test parts as opposed to throwing money at new parts.
Old Apr 16, 2013 | 11:03 AM
MelWff's Avatar
MelWff
Seems like coil is within specs. Did you pull the plugs to see if one of the cylinders is not firing? Did you do a resistance test on the plug wires? Did you look in the cap and at the rotor for evidence of carbon tracks?
Old Apr 16, 2013 | 01:00 PM
Kim72's Avatar
Kim72
New fresh plugs. Haven't tested the wires as yet. Will do that. Will be replacing cap & rotor. Still playing with this! It does get very frustrating!!
To MSD Blaster 2 Coil Test
