Help!! 82 won't start
Old May 6, 2002 | 09:44 AM
Calm Screamer2's Avatar
Calm Screamer2
Default Re: Help!! 82 won't start (82dukman)
I had the same fuel starvation problem with my '82. It turned out to be a rotten fuel hose. There is a small piece of rubber hose that connects the fuel pump to the steel fuel line. Of course it's in the gas tank. On mine, the hose was so loose and rotten it was almost totaly disconnected from the hard line. Result: Very little fuel pressure.
Old May 6, 2002 | 11:50 AM
82dukman's Avatar
82dukman
Default Re: Help!! 82 won't start (Calm Screamer2)
Here's the latest. Strated checking everything with test light. At tank fuel pump getting occassional power. Isolated the fuel relay and it was staying closed. Had a friend hold it open and now fuel to the injectors, but not spraying out. Called local Chev dealer and they said the relay controls the injectors too. He feels that this is the problem, bad relay. He ordered one for me aqnd it will be here tomorrow. I hope this is it, fingers crossed :(
Old May 7, 2002 | 01:17 AM
TJKirby82CE's Avatar
TJKirby82CE
Where is this relay located?-TK
Old May 7, 2002 | 09:20 AM
Calm Screamer2
Don't forget the oil pressure sensor. If the oil pressure sensor indicates low pressure it breaks the fuel pump power (Safety feature). You mentioned an oil change had just been done...so I figure maybe the oil pump is not primed due to a long time without running.
Old May 7, 2002 | 10:00 AM
82dukman's Avatar
82dukman
Calm, I have oil pressure which I can see by the guage when I crank it.
TK, the relay is mounted in the Battery compartment behind the drivers seat. It is between the ECM and the body wall, held in by 2 screws/bolts. A PITA to get out, :mad
[Modified by 82dukman, 2:38 PM 5/7/2002]
