Engine knock
Old Oct 17, 2011 | 08:09 PM
Mel07's Avatar
Mel07
4th Gear
Default Engine knock
Hi I have a 68 454- drove it a few times this summer and the last time out it started knocking about a mile from the house. It knocks LOUD when idleing and faster when pressing on the accelerator.
Any idea what this might be and a possible fix without a mechanic?
Thanks!
Old Oct 17, 2011 | 08:12 PM
l88rocket's Avatar
l88rocket
upper end or lower end?
upper end is a bad lifter, dropped valve etc,
lower is a rod knock and needs the short block rebuilt
You can start it take a stethoscope and listen around the engine
Old Oct 17, 2011 | 08:19 PM
LB66383's Avatar
LB66383
As he says, try to locate the noise with a stethoscope. You can also, with the engine idling, pull off the spark plug wires one at at time (carefully, there's a lot of voltage there!). If the noise goes away or diminishes, that'll tell you which cylinder it is -- usually indicates a bad rod bearing.
Old Oct 17, 2011 | 08:20 PM
Mel07's Avatar
Mel07
4th Gear
What do you mean by lower end or upper end. Sorry, I dont know much about the engine
Old Oct 17, 2011 | 08:48 PM
DRIVESHAFT's Avatar
DRIVESHAFT
Where do you hear the knock coming from?
Is it in the bottom part of the engine, or the top part?
Old Oct 17, 2011 | 11:07 PM
l88rocket's Avatar
l88rocket
lower end is crank, rods, pistons,
upper end is heads, cam, lifters, all the valve train componets
Old Oct 18, 2011 | 08:48 AM
69 Chevy's Avatar
69 Chevy
Here's a fact: no 454's were produced before 1970.
Old Oct 18, 2011 | 09:07 AM
ZZ71S's Avatar
ZZ71S
Is there oil in it?
Old Oct 18, 2011 | 09:56 AM
63split63's Avatar
63split63
After you check the oil level have an expierenced mechanic listen to your engine . The older he is the better.
LMO Bill
Old Oct 18, 2011 | 11:22 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by ZZ71S
Is there oil in it?
I'll go with a quart low.
Old Oct 18, 2011 | 11:25 AM
vanice's Avatar
vanice
Automatic? Check the torque convertor bolts
Old Oct 18, 2011 | 11:48 AM
forman's Avatar
forman
Do yourself a favor and have someone qualified look at your motor
Old Oct 18, 2011 | 12:10 PM
Mel07's Avatar
Mel07
4th Gear
Sorry.. yes 427
Old Oct 18, 2011 | 07:50 PM
63split63's Avatar
63split63
It would need to be more than 1 quart low to cause a knock .
Bill
Old Oct 19, 2011 | 11:59 AM
Mel07's Avatar
Mel07
4th Gear
Thanks for all the input. Its not the oil, that is where it needs to be. I am having it towed on friday to a professional. Fingers crossed it doesn't cost a fortune!
Old Oct 19, 2011 | 06:57 PM
Indiancreek's Avatar
Indiancreek
Put a timing light on it. Move it from one plug wire to the next until the flash matches the knock and that will locate the cylinder. The the timing of the knock will tell you it it's in the valve train or the bottom end.
To Engine knock
