battery charge
Old Oct 20, 2011 | 09:54 PM
namvet6869's Avatar
namvet6869
Default battery charge
is it ok to charge a battery in the car on an 81. have done it many times but read somewhere that it could harm the computer on an 81. thanks, namvet
Old Oct 21, 2011 | 11:27 AM
MelWff's Avatar
MelWff
If you charge at a rate of 2 to 10 amps it should not be a problem.
Old Oct 21, 2011 | 11:44 AM
RonR80's Avatar
RonR80
St. Jude Donor '09
Yes it's safe and agreed with above post, and don't start the car with the charger still plugged. Lower Amps is the best for charging.
Old Oct 21, 2011 | 08:44 PM
7T1vette's Avatar
7T1vette
If there is a risk to the car's electrical system, it should be described in the owner's manual. Otherwise, it shouldn't be a problem if you are not performing an "unusual" charging process.
To battery charge
