Thinking about removing the computer from my '81...I know I need to replace the carb and distributor.....the distributor is easy to find...but not so easy on the carb. And also, where is the vacuum source for the advance?....does it come off the carb?
I know others have been here so I am asking for guidance.
If it were me I'd stick to the ECM. It's not as hard to deal with as some people make it out to be. Unless you were planning on doing some heavy modding, I'd leave it there.
If you are asking where you get the vacuum for the advance can when you change the 'stock' system out, then you can pull it directly from the intake manifold vacuum fitting or you can connect it to one of the "new" carb fittings that is 'manifold' vacuum. {Note: A manifold vacuum fitting on the carb will 'suck' when the car is idling; a "ported" vacuum fitting will have zero vacuum at idle, but transition to a manifold vacuum condition once the throttle plates are opened a bit.}
Which vacuum source, ported or non-ported is the vacuum advance normally connected to?
Sorry I have to ask this, but it has been a long time since I have had a car that uses a vacuum advance.
I have had my '81 with the CCC system for over 10 years now and was just thinking of trying a vacuum advance distributor to see if there is any gain with the latest engine mods and pehaps the CCC is the limiting factor.
Again, just thinking....
The CCC is NOT a limiting factor. Save yourself a lot of wasted money and:
1. Tune the carb for performance (Adjust throttle plate opening, air valve etc.)
2. Get a hyperchip for ~$125 and set base timing around 12 BTDC.
This will give you everything you could get from a carb and timing. If you want more, spend your money where it will make a difference.
God bless, Sensei
I thought if you used a hypertech chip, you had to use the stock 6* base timing?
If its true you can run at 12*, I may get a hypertech that runs with the lower temp thermostat so I can run my engine cooler and the comp will still run in closed loop.
Another CCC 1981 bites the dust -- they are dyeing fast.
WHY do you want to get rid of the computer. The CCC will run the same as any Carb and Distributor combination that you put on the engine. The limitation in the engine is from the CAT and the heads. You can change both of them without making any modifications to the CCC system.
People say the CCC is a pain in the *** when it doesn't work right -- but it usually does not work right because something in the engine isn't working right such as Vacuum leaks, exhaust or intake leaks etc. -- But don't you want to diagnose and fix these anyway.
When I started my 1981 last year after about 10 year rest, it ran like crap -- After a few months of tinkering, I have fixed all the vacuum leaks, and exhaust leak, tuned the carb and the car runs GREAT -- smooth as silk on idle and acceleration . I feel like the engine is tighter and more stable than it ever has been. In my estimate -- the CCC helped me to uncover the problems that were in my engine that need to be addressed. You can blame the computer because it complained, or thank it for helping to diagnose issues that most people would never begin to look for.
WHOA....hold on there.....I was just thinking....have not actually purchased anything yet....am just thinking.
I have tuned the carb per Lars...as best as can be done with the E4M$ that is.
Car runs good....has Edelbrock Performer 70cc heads, Performer intake and the Luanti 60102 cam, headers and CCC all intact with the Hyper chip. The Hyper chip has been there for a long time as the PROM was dead when I got the car 10 years ago.
I think the engine is still running a bit rich and that is due to the cam, low vacuum and all...which is why I was thinking that taking the CCC out would improve this.
However something I just realized.....the MAP sensor is on ported vacuum....so the CCC is not monitoring vacuum at idle and is not adjusting the fuel mixture due to low vacuum.....
Hmmmmm.....I was thinking incorrectly.!!...
So unless I find the necessary parts at a FREE price....think I will just keep the CCC.
God bless the CCC 1981!!! (Soon to be the last?)
Same here, after I got the vacuum leaks fixed, and replaced the ECM (it fried on me). The car runs just like it did when it was new. Purrs like a kitten and runs smooth as silk. After working with the CCC, I am now a big fan. Now the trick for me is how much I can mod without taking out the CCC.
You can actually build an attenuator circuit for about $25 that can be used to fool the computer into thinking you have more vacuum than you actually have. As I have said before, the CCC system is stupid in the best possible way!
Your not the last! Still running the CCC even with a cam, head work, high flow cat and engine rebuild. Sure the carb took me a while to learn how it operates and tune, but it was fun to learn about it and it runs great now - lays down long black lines if I want, and still passes Ca. smog.
Your my hero man I want to follow in your footsteps!
These threads go fine until someone says they jerked the computer and never looked back would do it again....And thats me. I bought an HEI for cheap and a good Qjet off a 78 L82 that needs very minor adjustment for 50 bucks and the only thing I paid much for was the 150 for the B&M lockup controller. I said all that to say this, if mine ever acts up, all I have to diagnose is the normal stuff, not which freakin sensor it is, whether the idiot code light bulb is burned out or if the computer even works or if the E4ME 1 year carb is functioning properly and if not why? I have said before that I don't think my CCC was working properly but I had always planned to jerk it at my first oportunity and I did and have never regretted it. Much easier to work on and gets as good mileage as ANY CCC car, fires on the first twist of the key and idles as smooth as a babys butt. Just wanted to say a well tuned engine combo is a good ANYDAY as the 81 CCC system and much easier to diagnose issues if they arise from reading the "helpful" threads on CCC issues here I am surprised anybody keeps one on..... Just my cents because you kinda asked, I bit my tongue till now....flame suit on....
I still chuckle when I read how great the CCC is after you "figure it out", or "after a month of work". I spent an afternoon getting rid of mine and she purrs like a kitten. Would do it again in a heartbeat, but everyone has thier own opinion. I found an 81 while looking for a late model C3, I knew before I bought it that I would pull the CCC, to each his own. But to say the CCC is as easy to work on as a non comp car is simply nonsense.
From: Las Vegas - Just stop perpetuating myths please.
U won't gain much on a modest performance engine by removing the computer..
I recall the computer just controlled the primary side of the electric Qjets. The secondary side is still tunable for performance. Meaning u have to live with stokiometric 14.7 A/F ratio just until the secondaries kick in. So u can still tune richer at WOT. I also believe that all OBD I (and many OBD II) computers become open loop on WOT - meaning they no longer look at the A/F ratio from the O2 sensor to adjust mixture. And they can't anyways. The mixture solenoid is in the primary side of the carb (u can see that for yourself). And u can change the secondary metering rods in less than 5 minutes on any Qjet.
My 2 cents is it would take a lot of performance mods before it would require removing the computer and electric carb.
cardo0
cardo0
You are correct on how this system works. Living in Ca. I have to keep my CCC working or it wont pass smog. Yeah it is harder to tune than a non CCC car, but I take a certain sense of pride in being able to figure it out, and once set up I havent had to work on it since - its not like these cars are rocketships either way!
