Tripower
Old Oct 20, 2011 | 11:39 PM
AvRog's Avatar
AvRog
Default Tripower
Anyone have a photo of the return springs set up for a 69 Tripower?
Old Oct 21, 2011 | 12:02 AM
69FASTFUN's Avatar
69FASTFUN
This is the only photo I have
Old Oct 21, 2011 | 01:40 AM
CA-Legal-Vette's Avatar
CA-Legal-Vette
That looks fantastic! How did you redo the finish on the carbs?
Old Oct 21, 2011 | 12:31 PM
Wrencher's Avatar
Wrencher
If you study the spring and linkage design (which is correct in this photo), you will notice that the throttle cable and spring work against each other using the trottle body as a fulcrum. This leads to the very common badly worn throttle body and mixture problems due to vacuum drawing air past the shaft. By adding a spring that attaches at the top of the linkage (I use the large hole) and the front fuel line, it unloads the throttle shaft and greatly reduces the wear on the throttle body. This really only needed if it is driven much. Mine was worn out when I got it so I added bushings to the throttle body and the aforementioned spring. I drive mine daily.
The Quadrajet equipped GM cars have the same issue, and benefit from the same fix.
For the NCRS folks, you can just remove the added spring for a show.
Hans
Old Oct 21, 2011 | 01:16 PM
AvRog's Avatar
AvRog
Hans
Hans, excellent advice and I will follow! Thank you
To Tripower
