triangular air filter
Old Oct 21, 2011 | 01:12 PM
rzkas's Avatar
rzkas
Default triangular air filter
hi? i have a 82 corvette with a small block engine. i have a edelbrock performer intake with a edelbrock carb. will the triangular air filter work with my car? hood clearance issue
thanks
http://cgi.ebay.com/Edelbrock-1002-P...sories&vxp=mtr
Old Oct 21, 2011 | 02:04 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
What type of hood are you running now? The 82 crossfire hood was one year only and had air intake routing for the X-fire.
Old Oct 21, 2011 | 05:42 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
DO NOT USE THAT Breather!! 1 backfire and it goes up in a FireBall.
You do know what you get when you fix Fiberglass, Gas, and fire !
I used 1 temporay with no hood during my build process, it will burn, and so will your hood!
and the rest of your Corvette.
Old Oct 21, 2011 | 06:26 PM
Ganey's Avatar
Ganey
Should fit, but as said not a good choice. If it burns a mess in carb too.
What's on it now?
Old Oct 21, 2011 | 08:04 PM
rzkas's Avatar
rzkas
stock 82 corvette hood i will be using
Old Oct 21, 2011 | 08:05 PM
rzkas's Avatar
rzkas
What's on it now?
it has one of those round filter
Old Oct 21, 2011 | 08:08 PM
rzkas's Avatar
rzkas
how about this type triangular filter. i heard triangular filter gives out a better sound and breath better, is it true or false?
http://www.ebay.com/itm/14-Chrome-Tr...item519b67851e
Old Oct 21, 2011 | 08:26 PM
Ganey's Avatar
Ganey
Round is best. If low enough still fine though. You need to check clearance & give nos. on yours since you have a carb on 82.
Old Oct 21, 2011 | 09:13 PM
Mod75's Avatar
Mod75
2024 C3 of the Year Winner - Modified
Yes the triangular fits in a tight spot, but the black foam deteriorates and turns into black crumbs.
With a backfire it will melt some of the material.
Took me five years to figure it out
Old Oct 21, 2011 | 11:00 PM
terry82's Avatar
terry82
i used round ones .but i still have the throttle bodys.http://85fuelpump.shutterfly.com/pictures/25
To triangular air filter
