Gas tank sending unit
Old Oct 21, 2011 | 11:34 PM
xpoc454's Avatar
xpoc454
Default Gas tank sending unit
I just happen to have access to my gas tank currently due to repairs.
My gas tank guage has never worked since Ive owned the car and currently is showing way pass full.
Once I removed the spare tire cover I noticed what I was told was the ground wire, was not even connected. I've tried to ground it but it hasnt made any difference.
Is there a electrical test I can do the gas tank sending unit to see if it is bad?
Old Oct 21, 2011 | 11:44 PM
oldsarge's Avatar
oldsarge
Could be sending unit, or wiring or even bad gauge. If you do a search here on the forum, you will find all kinds of posts on this topic and it will help you find your problem.
Old Oct 22, 2011 | 12:31 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
You say the gauge is pegged past full.. but where is it pointing? 3 or 4 o'clock? This helps you id the issue.
3 is a missing ohms input wire, 4 is a gauge missing a ground.
Go to this link.. there is enough info on there for anyone to fix their gauge.... I hope..
http://willcoxcorvette.com/repairand...lp.php?hID=276
Old Oct 22, 2011 | 03:40 PM
xpoc454's Avatar
xpoc454
It is setting at the 3 oclock position.
I got under my car and noticed the ground wire at the sending unit is not attached to anything.
I than looked at the sending unit and the tab that the the wire would connect to, appears to have broken off.
SO I than tried to get connect the ground manually and still the fuel guage looks the same.
I went to the web page listed and tried the resistance on the sender unit. I set it to 200ohms and put one tester lead on the male pin and another tester lead on the place where the ground connection appeard to have broken off.
When I do this I still get open circuit on the ohm meter.
I assume this means the sending unit is bad or could there be another explanation?
thanks
Old Oct 22, 2011 | 09:33 PM
0Willcox Corvette
Former Vendor
If you are testing the output on the sender and its open then yes.. you have a sending unit issue.
If you wish to test the gauge function remove the input wire from the sender and ground it out. The gauge should go to empty.
Do this and I'm certain you'll find your issue is the sending unit.
Willcox
Old Apr 30, 2020 | 07:53 AM
Don Ferestad's Avatar
Don Ferestad
1st Gear
Default 79 fuel gas past full
Missing 12v or gauge ? I found an easy access without dropping tank on 77 to 82. Remove gas door and bladder. Test for voltage to determine if sending unit,open or gauge defective. My problem was an open.. My point is you don't have to drop the tank or remove dash to determine the direction of the problem problem. I fixed mine in 20 minutes.[Lucky]
I hope somebody reads this because it will save you hours if you start at wrong end. DataDon
Old Apr 30, 2020 | 09:10 AM
JavaJolt78's Avatar
JavaJolt78
Hey there DD,
Can you please expand on your quickie fix/test for a very experience limited senior??
I have a 78 and would like a more clear cut explanation!!
Cordially,
javajolt78
Old May 14, 2020 | 09:17 AM
tedstiles's Avatar
tedstiles
1st Gear
My C5 fuel guage not working. Error code "PCM" clears it but it quits again AND runs out of fuel at greater than 1/4 tank of fuel
To Gas tank sending unit
