Starter!! problems
Old Oct 23, 2011 | 12:27 PM
jdeel92's Avatar
jdeel92
Default Starter!! problems
okay so long story but here it goes so everyone knows the details......
when i turned the ignition nothing at all would happen no nothing. i tried for a minute or so it started just fine. next day basically same thing happened.
i though it was the starter so next time it didnt turn i hit the starter with hammer. that worked for a day or so then that quit working too.
so i had good reason to belive it was the starter.
NOTE: it only had this problem when it was cold after i got started the first time that day as long as it didnt sit no longer than a hour or something it would start up just fine.
i buy a new starter take the old one off actually me and my dad would take turns going up and under there trying to take it off. but in that process we both forget were they were originally. ive been to two diff parts stores and got two diff answers ive also got different answers from other people so im lost.
okay and next for ***** and giggles i take the old starter to the auto place to have that starter tested. it passed the test so for those purposes the original starter is good.
so i still dont know what the problem is also i still dont if i have this thing wired up right? here is a pic of the original
sorry for the length of this.
i just had to explain it.
any suggestions or help and or questions would help me out thanks!
Old Oct 23, 2011 | 01:39 PM
Ironcross's Avatar
Ironcross
clean the short ground cable from the battery attached on the frame....cures most of the cranking problems like you experienced...means getting under the car again and easily overlooked and blamed on the starter
Old Oct 23, 2011 | 03:05 PM
jdeel92's Avatar
jdeel92
thanks! i will check out that some time this evening
Old Oct 24, 2011 | 10:41 AM
jdeel92's Avatar
jdeel92
do you know how the wires go. ive been told the two main ones go on the same big bolt.
the smaller one goes on the little right post closest to the engine
but im really just lost
its a 78 btw
Old Oct 24, 2011 | 11:10 AM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
the auto part store, starter test is no load, .....a useless test.
specifiy wire colors, and be very careful, or you will smoke your wiper motor.
There is a small black wire that appears it should go with the main positive cable,
because it has a large lug connector. IT GOES to GND. .....NOT +12V
Purple wire goes to "S" Start.
Old Oct 24, 2011 | 12:23 PM
jdeel92's Avatar
jdeel92
were is GND?? at i have the small purple wire hooked up right i believe the red wire goes on the main bolt above both the smaller posts were does the black go?
Old Oct 24, 2011 | 12:48 PM
Peterbuilt's Avatar
Peterbuilt
The black wire connects to a starter mount bolt or a bell housing bolt, it is the ground wire for the wiper and heater fan motor.
Old Oct 24, 2011 | 05:59 PM
69Vett's Avatar
69Vett
hopefully your motor has a (big battery size) gnd. cable going from the frame,
to your engine block. connection point should be around the starter or passanger side motor mount.....that makes your motor Gnd.
Old Oct 25, 2011 | 10:59 AM
BKarol's Avatar
BKarol
I'm just getting a red x for the pic.
I just took the starter off my 78 yesterday and can take some pics of the wires later if you think it will help. I will send them to you.
or if you solved the wiring issue let me know that.
Old Oct 25, 2011 | 11:33 AM
jdeel92's Avatar
jdeel92
That would be great if its not to much trouble!
Old Oct 26, 2011 | 09:35 AM
BKarol's Avatar
BKarol
PM sent yesterday afternoon.
If it doesnt help then you need to post some pics of what you have for wires you are stumped on.
Old Oct 28, 2011 | 05:14 PM
jdeel92's Avatar
jdeel92
STARTED WE ARE IN BUSINESS!!!
thanks to every one this forum is BOSS
Old Dec 9, 2011 | 04:26 PM
richardttu's Avatar
richardttu
For my curiosity, what problem did you fix?
Old Dec 10, 2011 | 01:47 AM
jdeel92's Avatar
jdeel92
Starter
Old Dec 10, 2011 | 04:05 AM
7T1vette's Avatar
7T1vette
Did you replace the starter solenoid also? That is [was] most likely the problem. It could still have been the starter (due to damaged/worn brushes/commutator), but with intermittant symptoms, the solenoid is a better "bet".
Old Dec 10, 2011 | 08:10 AM
jdeel92's Avatar
jdeel92
Actually just the starter its done fine ever since lol
Old Dec 10, 2011 | 06:27 PM
7T1vette's Avatar
7T1vette
Glad to hear it.
Old Dec 10, 2011 | 08:25 PM
C3 Shark's Avatar
C3 Shark
3rd Gear
Glad to hear it.
C3's have starter issues because of a flaw in the design. When the starter brushes start to get worn, they are prone to heat. What the heat does is to affect the brushes where they may not contact the contacts on the starter shaft. When this happens, the car will not start. But if you bang on the starter, they usually will make contact again allowing the car to start. A better way is to pour water on the starter which will cause it to cool just enough to allow the brushes to make contact. I think that the problem lies in the springs which hold the brushes. The problem is amplified on cars where headers are used. Many people just replace the starter which is a temporary fix. Most will take the starter and have them tested at the auto parts store which usually finds no defects in the starter.
Old Dec 10, 2011 | 10:51 PM
sly vette's Avatar
sly vette
Would this not then apply to all G.M. starters?
To Starter!! problems
