What would you recommend be done to an engine that sat for a year? This is a build up SB 400 pushing 450hp, I want to install it in my 1972 so it is drivable while I am rebuilding the original motor. Thank you in advance.
It depends on if the motor has been run before and the cam is broken in. If that's the case you should check all fluid levels, pull the coil wire so there's no spark to the plugs, turn it over until you see good oil pressure, and then fire it up. Some folks would just start it w/o that and call it good. Do make sure there are no fuel leaks before you fire it up, for obvious reasons. Carb gaskets can go bad when they sit too long and it's always good to double check fuel lines anyway.
If the motor has been built but never fired you'll need to determine what kind of cam is in it to see if it needs to be broken in. You'd also be wise to pull the distributor and prime the oil pump until you see good pressure. I won't write a book on cam break in since you can do a search and find all you need on that.
Very good advice, but I know Les personally. He'd grab the flywheel and spin it really fast for a couple minutes, then drop it in, bolt it up and hit the road.
Preoil the heck out of it while it's on the stand and make sure all the seals get a touch of oil. Put a squirt of oil in each cylinder, then turn the engine by hand through a couple of rotations. The idea is to get it good and wet before dropping it in.
Then preoil again right before the start - and cross your fingers
IMO, a year isn't really a long time for an engine to sit. I would imagine some of the less often ordered crate motors can sit in a warehouse that long. After preoiling, my main focus would be the carb & fuel lines.
A tip from experience: check and recheck everything several times. Its much better to find that bolt or hose clamp that was just snugged before you start the engine.
Sounds like a fun project, maybe you'll have some pics?
I'd follow the advice already given. But I'd start it and check for leaks, etc BEFORE dropping into the engine bay. Weld up an angle iron stand, or if you lack welding skills, screw together some framing lumber to match up to the engine mounting pads. It's not like you're gonna rev it to 6 grand, just idle to off idle will tell a lot about its condition.
Thank you everyone, from my understanding the car ran and driven to the spot it is parked now until the mice got to the electrical and would not start. I will definite follow all the advice posted. Thank you. I think I really have the bug for driving Iconic car after years of Bimmers.
My club has done their job converting me to enjoy Corvettes.
