The stock Q-J has sec. air spring adj. screw behind the lever to air valve & an Allen lock screw. Loosen Allan lock screw & tighten adj. screw.
Since it is for a 327, a quick check on the jetting is in order. Sec. has a screw at top middle that holds the hanger & sec. rods. Check letter on hanger & 2 letters on rods.
accel shot is fine, I've heard that there not change able to make work.
But thats just what i have been told, Do i need parts for this? oh and another thing, i neutral at idle if i hit it pretty hard it dies off too. timing is set perfect dwell and all the advance bla blah works exactly how the engine book i read said
Very typically, a bog on acceleration is caused by the secondary air valve spring being too loose, and allowing the secondaries to open too soon. Try setting the spring to 3/4 of a turn and see if that improves anything.
There is a fellow named Lars Grumsfeld (I hope I spelled that right) that has a website that lists the specs for many Quadrajet applications, including the jets and rods used in each application.
If you are swapping the carburetor from one engine to another, you will likely have to retune the carb to match. If you are handy, it's not difficult. Find out what was stock for your replacement engine, and install the same jets and rods. That will be a good start.
Good luck to you.
Can you post a pic of the passenger side of the carb? There should be at least one small vacuum canister ther e and linkage to the secondary flaps from the canister. Posting a pic may may help others identify this?
Chilton & the chassis manuals also explain the procedure. I noticed on the dyno that my valve didnt open at all. Adjusted the tension and made a big difference. Just something to look at. Probably need a mirror to see what you are doing and dont let allen screw come out. Good luck.
Usually you dont have to touch this but it's not your carb so you dont know what the po did. You do have to make sure the choke is operating correctly first.
