Cam and Valve Train Change
Old Oct 27, 2011 | 05:55 PM
bigvette1's Avatar
bigvette1
Default Cam and Valve Train Change
Has anyone changed the cam, timing gears, balancer etc on a BB stil in the car by removing the radiator??
Or
Is it just as easy to pull the engine to do the job??
Old Oct 27, 2011 | 06:00 PM
Ganey's Avatar
Ganey
I have w/ a SB & it would work w/ a BB, note the long nose area w/ rad. out.
Old Oct 27, 2011 | 07:03 PM
Gordonm's Avatar
Gordonm
Leave it in the car and do it. Unless you want to pull the engine and get involved in the while its out syndrome. It will end up costing a whole lot more by pulling the engine. Probably turn into a frame off!
Really not a bad job with it in the car.
Old Oct 27, 2011 | 07:27 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
A very accurate observation, that.
Old Oct 28, 2011 | 07:26 AM
bigvette1's Avatar
bigvette1
God is that true. Start with one small project and end up with "way too many while I am at it projects". Thx.
Old Oct 28, 2011 | 07:51 AM
68/427/vette's Avatar
68/427/vette
I changed the cam in mine just a few months ago, pop off the hood and radiator. and there you go, room for days mine is a 427 as well.
Old Oct 28, 2011 | 12:04 PM
pawpaws toy's Avatar
pawpaws toy
Sorry to jump in but I was wondering the same thing. I have a 1980 with small block. Will the A/C condenser have to be removed also? I was measureing and it seems awfully close.
Old Oct 28, 2011 | 12:09 PM
68/427/vette
I have some pictures of me doing my 427 I had to use the entire nose of the car to pull mine out. That was in a bb tho. measure the block front to back, then from the front of the block towards the nose and see what will clear and what wont.
Old Oct 28, 2011 | 06:00 PM
bigvette1's Avatar
bigvette1
Yes it may be close. I plan on pulling the AC condensor out as that just gives you both physical and visual access to the front of the block. The charge in the system, I guess I hope to find a shop that will evacuate the system and "save" the stuff for a later flush and recharge. That is a draw back.
Old Oct 28, 2011 | 06:11 PM
Ganey's Avatar
Ganey
On a SB, I just loosened the condenser.
bigvette1
Yes, on a BB may need to remove the condenser.
To Cam and Valve Train Change
