MSD location
Old Oct 28, 2011 | 06:55 AM
Dr L-88's Avatar
Dr L-88
2025 Corvette of the Year Winner- Modified
2024 C2 of the Year Winner - Modified
2022 Corvette of the Year Finalist -- Modified
2021 C2 of the Year Winner - Modified
2021 C1 of the Year Winner - Modified
2020 Corvette of the Year (stock)
C2 of Year Winner (stock) 2019
2017 C1 of the Year Finalist
Default MSD location
Just curious where you are mounting your MSD boxes. Is anyone mounting it in the interior away from heat and vibration? Post pics if available.
Thanks,
Rex
Old Oct 28, 2011 | 07:00 AM
scottw's Avatar
scottw
Engine compartment, pass side between wheel well and firewall. Been there about eight years with no issues.
Old Oct 28, 2011 | 07:04 AM
njfl's Avatar
njfl
Mine is mounted on the back side of the map pocket (69). The map pocket hides the mounting screws.
Old Oct 28, 2011 | 08:20 AM
ro919's Avatar
ro919
Inside on trans tunnel where radio used to be.
Old Oct 28, 2011 | 01:57 PM
glackore's Avatar
glackore
Sorry, no pics but mine is behind passenger side dash panel.
Old Oct 28, 2011 | 02:10 PM
Mako72's Avatar
Mako72
2018 C3 of Year Finalist
Mounted mine on the pass side wheel housing. Mine doesn't have an overflow tank there, so plenty of room. 10 years now.
Old Oct 28, 2011 | 02:34 PM
Roughrider's Avatar
Roughrider
That works great for me as well. Out of sight and no problems of any kind. My car has no a/c so whether duct work for that may make a difference I can't say.
Old Oct 28, 2011 | 02:44 PM
68-427Rich's Avatar
68-427Rich
Default Msd
Mine came with an extension cable, distributor to control box, I put the box in the jack compartment.
Old Oct 28, 2011 | 02:47 PM
MelWff's Avatar
MelWff
have a CD box mounted on wheelwell passenger side for decades
Old Oct 28, 2011 | 02:52 PM
GS977's Avatar
GS977
on the trans tunnel inside the car on the pass side, up high around where the ashtray is. if that makes sense. it still gets warm even in the interior. i'd hate to see how hot it gets in the engine compartment
Old Oct 28, 2011 | 04:13 PM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
behind the passenger seat in the compartment.
Old Oct 28, 2011 | 08:29 PM
billcarson's Avatar
billcarson
the po thought it would be nice to have it support your passengers feet, while the remote timing box cut your ankle.i relocated where it would not be seen.
Old Oct 30, 2011 | 08:10 AM
tekvette's Avatar
tekvette
I mounted mine up and down longways behind the passenger side wheelwell under the coolant overflow tank. I'll try and take pics later for you, I'm going to be working on the car tday.
Old Oct 30, 2011 | 09:40 PM
Hodge's Avatar
Hodge
Thanks,
Rex
put it under the hood. I made the mistake of putting a 6AL behind the glove box on a 1966 GTO. It was LOUD. every time it fired a spark plug you could hear it. As far as vibration, what is the difference. it vibrates just as much inside the cabin as it does under the hood.
Old Oct 31, 2011 | 01:30 AM
Kim72's Avatar
Kim72
I guess mine is a little different. I mounted it out in front of the radiator on a flat bracket I made up. It works great, seems to stay cool, and people can still see it with the hood up.
Old Oct 31, 2011 | 06:37 AM
RobMac216's Avatar
RobMac216
6th Gear
behind the passenger seat in the jack compartment here too
Old Oct 31, 2011 | 09:42 AM
bigvette1's Avatar
bigvette1
No one mentioned a place I put a Crane HI-6. In front of the AC condenson on brackets down by the vacuum tube. Been there for 8 years or so and has not failed or caused any grief. Also can get to the rev limiter switches which if mounted inside behind the passenger dash is tough at best.
Old Oct 31, 2011 | 11:52 AM
opnwide's Avatar
opnwide
I placed mine where Kim72 put his, of course I've got a '72 as well.
Old Oct 31, 2011 | 03:51 PM
Kid Vette's Avatar
Kid Vette
Mine is where the windshield washer bottle used to be.
To MSD location
