light flasher location?
Old Oct 28, 2011 | 08:33 AM
bgall2's Avatar
bgall2
Default light flasher location?
Hey Guys. I know my 78 has 2 light flashers and one is on the fuse panel under dash under steering wheel. Where is the other one, exactly please? And, if anyone knows, which kind should I be using? Thanks. Bob
Old Oct 28, 2011 | 08:53 AM
fanmanbd's Avatar
fanmanbd
Not sure on your 78 but on my 73 it is under the passenger side dash by the door.
Old Oct 28, 2011 | 09:23 AM
Paul L's Avatar
Paul L
Have a peek in that area.
Old Oct 28, 2011 | 02:07 PM
Mako72's Avatar
Mako72
2018 C3 of Year Finalist
Just replaced my flasher a couple of weeks ago.
Your's may be located differently but mine was located behind the pass side map pouch. OEM was a Tung-Sol 224 which I replaced with a NAPA 552. Works perfectly.
Old Oct 28, 2011 | 02:14 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Owner's manual probably shows the location.
Old Oct 30, 2011 | 09:01 PM
bgall2's Avatar
bgall2
Thanks a lot guys....again. Found the light flasher hid under the passenger side dash. Replaced and all my blinkers work fine....and I have the noise as well.
Bob
To light flasher location?
