I would probably buy a craftsman click. I have been using the same SnapOn click for 25 years. I had it calibrated one time a couple of years ago and there were no changes to calibration. I always turn it down to 7-9 lbs when done.I always keep it in the original plastic box too.
I will keep this short. I have a Harbor Freight clicker wrench that I had some question on accuracy. A friend also had the same wrench and took it to a buddy with an SCCA race shop and had him check it. He used it against his brand name wrench and it was dead on the same at all ranges tested. I went to an aviation engine shop to have mine calibrated, but changed my mind when they wanted $90 for the calibration test. The wrench only cost me about $12. I bought a beam torque wrench from Advanced Auto and a coupling nut from Ace Hardware and mated the two to test/compare calibration. My eyes are not good and my reading the calibrations on the click wrench was in question. Now, to double check my setting, I always use the beam wrench before cinching down the set screw on the clicker. I have not found anyone who found the Harbor freight clicker wrench inaccurate. Remember, you need to store it with tension off the adjuster. For what it is worth, this is my opinion and experience.
Snap on is one of the best. I own 3 different Snap on TQ wrenches and about 5 other brands. Snap on is #1
I have an old 1/2" drive Bonny (600 # ft), a 1/2" drive Mountz(150 # ft) and a 3/8" flex head Snap-On. I use the Bonny as a hammer sometimes; it's cool. There's also an old Craftsman beam type and a cheapo clicker, but I don't use 'em.
Thought for you. I have checked the calibration of my torque wrenches, beam, clicker, Craftsman and Husky by chucking the square drive in your vise with the wrench in a horizontal position, tie a string to the center of the handle and add known weights until it clicks or reads on the beam indicator. All checked pretty good except a cheapy 3/8 drive auto parts store version. I believe all are better in the middle ranges than on the extremes. Measure from the center of the handle to the center of the square drive in inches or feet. Multiply that by whatever weight you have added and there is your inch lbs or ft lbs.
Hope this helps.
That's a cool idea. I guess the problem would be finding a "known" weight. I suppose you would need a "postal" scale. I have 3 bathroom scales and they all disagree. The weight and the measurement would have to be dead on.
A 'beam'-type torque wrench made by a good manufacturer will always be correct [unless the wrench has been physically damaged or bent]. The amount of bend in the beam, at different torque levels, is consistent and plenty accurate. Click-type wrenches depend on the user releasing the load on the wrench precisely at the point it clicks...and, on the internal spring system that causes the 'click'. They are not as consistent and accurate as beam-type wrenches. Digital units require electronics to be calibrated occasionally and can be temperature sensitive.
For the 'weekend garage warrior', the beam-type wrench is the best choice, IMO.
I'm a Craftsman guy, and have the click-type wrenches. They go in for calibration once a year.
Any precision tool should be regularly calibrated. Don't go to an aviation shop to have this done, as they are required to do additional paperwork...and so have to charge for it. The mfgrs are usually the cheapest route, although the turnaround time can suck. Snap-on is by far the quickest...I'm the only one in my circle of buddies that isn't Snap-On, and I always take flack for it
Trying to recall the last time I've seen a beam-type wrench in any builder's shop. They're darn hard to use in-car; remember that torque is a twisting force...so the beam is only accurate if you stop turning exactly when the reading is correct, and the only time you can see the correct reading is *directly* over the scale and pointer...try that on an installed SBC head bolt towards the back
Click wrenches are "auto-magic" - set the torque and turn...and the release (click) is pretty distinctive. I've never heard of anyone continuing to apply turning force after the release. For a novice, they're by far easier to use - but they are certainly more expensive and do require periodic calibration.
