The pre-oil does a few things - it makes sure everything's working, and it makes sure everything's wet I this case since it's just a top it's really not an issue other than to make sure the oil is coming up through the pushrods.
The easy way to set static timing is to bring the engine up on compression stroke #1 - just put your finger over the hole while someone "bumps" or manually turns over the engine. Then move the engine so the timing mark is at about 12-16 degreest BTDCC...you can eyeball it Then install the distributor so that the rotor is pointing directly to the #1 tower. The easiest way to do this is to mark the centerline of the #1 tower on the distributor body, then measure back 1 - 11/16" for a standard distributor or 2 - 1/4" for HEI and make another mark. Line up the rotor with this 2nd mark and drop it in...if the distributor won't drop, then just bump it until it does. Then double-check and see if any final adjustment is required. I'm making this sound too hard - it's actually pretty quick
You can fill the carb bowls through the bowl vent - what kind of carb again?
So I got the 383 engine set in and hooked up. I figured out the problem with the first attempt in starting it - plug wire fiasco. I can't believe how easy it is to be certain everything is just right then - BAM - you find out you are an idiot! After I walked away and thought about it a minute when I wasn't looking it came to me.
The engine is in and running. Had a few hiccoughs and a couple of near chokes! I'll post details and pics later.
Before I can take any pictures of the finished product I need a couple of pieces. How have people been attaching the throttle cable, the transmission kick down cable, and the brake vacuum line to the Edelbrock Performer Vortec intake manifold? The stock brackets don't fit on the new intake so I need a new mounting strategy.
Are you sure the stock bracket doesn't fit? On my 77, I used the stock bracket on a Performer manifold and now on an RPM air gap. See the pic below.
what hood are you running with the air gap intake? And if you dont mind what is your car running?
Stock hood - and there is an adapter under the carb. With a drop base air cleaner it just fits. I can't use a wing nut on the air cleaner because it contacts the hood. I ran 12.40 at 107 last month.
Nice! I am also using a stock hood and drop base air cleaner. Haven't put the hood on to see how close I am yet.
I have different attachments than your '77. Are they stock? I will post some pictures. I thought it was b/c you didn't have the vortec intake but I see that we have the same 8 bolt intakes.
Here is a couple of pics of the old brackets on the intake manifold. Ignore the extra Qjet on the dizzy in the first pic.
I realize now that the bracket for the throttle cable is the same. Maybe I just need to work with the one holding the other cables? Did you remove the vacuum canister to the drivers side of the distributor?
I have a '80 'vette with stock hood,2101 Performer and dropped base air cleaner using 3" element, I have almost an inch of clearance, you should be just fine.
Scott
I hope so. The 2101 has heights of 3.5" and 4.6" listed http://www.edelbrock.com/automotive_...ormer-sb.shtml while the 2116 vortec intake is listed at 3.87" and 5.28" rise.
Are you running a Qjet? I was thinking about playing with a Holley and a couple of Edelbrock carbs (I don't have any alliance, just for my own education and S&Gs) I have but I guess not, especially if they need an adapter.
Did you have to modify the linkage I am point to in your pic? As you can see from the pics from my old engine it runs to a vacuum drum that, as far as I can tell, never had any effect on the throttle. Although that likely means that mine isn't adjusted correctly, I don't really see the purpose.
can you tell me more about your setup? mine ran 13.16 its a 350 bored 60 over with flat tops a small cam stock brand new vortecs with the eps intake 750 edelbrock its a 4 speed car it takes off slow at the track ii guess cause of the 3.36 gears. what gear are u running?
i wish i would have known the air gap would cleared lol but i guess its not that much difference in the height of them but the air gap is better for the bigger cams
I did not know that the Performer Vortec was so much higher than the regular Performer. You may be cutting it kind of close. I have the 2101 (spreadbore) using a 600 cfm vacuum secondary Holley squarebore. The adapter plate and gasket only take up about 1/8", and like I said, I have a little less than an inch, and that's not counting the wing nut. About 1/2" from wing nut to hood. I could maybe squeeze another 1/4" or so with a deeper dropped base aircleaner, but then the throttle cable is in the way. And, ya don't want the top of the aircleaner too close to the top of the carb, so you can only go so far with the dropped base, anyway. I think you'll be cutting it close, but you should be able to make it, let us know how it works out, as I keep thinking about maybe trying to fit a Performer RPM under my hood. Good luck!
Your green arrow is pointing at the trans detent (downshift) cable in my picture. The cable on yours coming from that canister next to the distributor is related to your cruise control, I believe. My car doesn't have cruise. The trans cable should work fine on yours using the original bracket, which attaches to the back two bolts on the carb. I had a Performer (8 bolt Vortec type) manifold on mine previously.
greg - If your question here is for me, click on the BKbroiler name in my avator and you can see my profile with all the info. (I don't want to hijack this thread.) You can PM me with any questions.
Thanks, that helps a bunch! I have seen several pics of '80s both with and without the cruise control diaphragm. My car has that diaphragm in place but didn't have cruise control when I got it. Needless to say -> lots of confusion. I will just pull that piece until I decide to put cruise back in... lots of projects above that on my list!
As you can see on this pic, the bracket for that diaphragm has two holes that fit in the top of the intake and one that fits on the back side of the drivers side head. B/c the vortec heads/intakes have 8 bolts instead of 12 the bolt spacing is different. How did you attach this bracket? Should I just cut one of the bolt holes off the bracket?
I don't know if the bolt spacing is different or is it just that the 2 middle bolts on each side are eliminated and the remaining bolts are verticle rather than on an angle? Anyway, your question reminded me that I modified the bracket for the trans cable by cutting it and bending the bottom tab so when bolted in, the cable support point is in the same location as stock.
