engine light on 81 vette
Old Nov 3, 2011 | 09:49 PM
tuyen71's Avatar
tuyen71
2nd Gear
Default engine light on 81 vette
i have a problem on my 81 vette i just install side pipes and hooker header on it and now my engine light went on and it stay on i dont know what to do can any 1 out there help me? thanks alots
Old Nov 3, 2011 | 09:52 PM
forvicjr's Avatar
forvicjr
remove the ecm
Old Nov 3, 2011 | 09:58 PM
tuyen71's Avatar
tuyen71
2nd Gear
what is ecm?
Old Nov 3, 2011 | 10:46 PM
larryg3's Avatar
larryg3
Did you keep the O2 sensor on the car?
Old Nov 4, 2011 | 12:02 AM
7T1vette's Avatar
7T1vette
The '81 car had the first version of electronic controls for the engine. It had a unique (one year only design) carburetor, distributor, and ECM (electronic control module...computer). It also had an oxygen sensor in the exhaust downpipe which sent emission data to the ECM for regulating fuel mixture and distributor timing.
If your "Check Engine" light is on, there is a trouble code that has been logged into the ECM. You need to download that code and address the respective hardware problem indicated by the code(s).
Old Nov 4, 2011 | 10:08 AM
a1sensei's Avatar
a1sensei
Originally Posted by forvicjr
remove the ecm
Avitar says it all.
Listen to 7T1.
Old Nov 4, 2011 | 11:58 AM
SIXFOOTER's Avatar
SIXFOOTER
7T1 and A1 are correct.
You may not have installed the O2 sensor back in the drivers side header.
No reason at all you can't make significant HP gains With the CCC in place and functioning
Old Nov 4, 2011 | 12:20 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Bingo.
Old Nov 4, 2011 | 01:04 PM
RonR80's Avatar
RonR80
St. Jude Donor '09
Yes my first thought 02 sensor.
Old Nov 4, 2011 | 01:17 PM
wajulia's Avatar
wajulia
The computer will tell you why -- read the codes. To do this, pull the ash tray, there is a connector directly under it. With engine off, short the two pins closest to the driver side. turn on the key (not the engine) the check engine light will begin to blink (you will also hear an audible clicking in the engine compartment, it is the carb mixture solenoid switch and is normal). One blink, pause, two blinks (code12) and repeat that three times. After the code 12 (normal, happens every time) there will be one or more codes blinked at you (example: Blink, Blink pause, blink, blink, blink is code 23). It will blink each code three times. When all codes are complete there will be another set of three 12's. When you see the 12 again you are done.
Let us know what the codes are and we can help you from there. Also, think about getting an 81 service manual, fantastic section on the CCC
My first thought -- did you connect the oxygen sensor back up, should be on the downtubes of the drivers side header
Old Nov 4, 2011 | 01:24 PM
htown81vette's Avatar
htown81vette
Since he just installed headers and sidepipes it pretty obvious it is a missing 02 sensor, in which case you have 2 options:
1) weld a bung into your sidepipe or header and re-install the sensor, or
2) Remove the ECM, which means you'll also have to replace the carb and distributor.
Old Nov 4, 2011 | 02:01 PM
atikovi's Avatar
atikovi
How about a picture. I don't think I've seen a late C3 with side pipes.
Old Nov 4, 2011 | 02:05 PM
htown81vette
^ x2
Old Nov 4, 2011 | 04:30 PM
larryg3's Avatar
larryg3
I do not mean to hijack the thread but here is a pic of my '81 vette. I put on the hooker headers and side pipe this year.
Old Nov 4, 2011 | 04:33 PM
htown81vette
sweet!
Old Nov 5, 2011 | 11:30 AM
forvicjr's Avatar
forvicjr
Yup a1 thats my car in its present state, and it still probably looks better than yours.
To engine light on 81 vette
