Help with Clevis
Old May 6, 2002 | 08:23 AM
ed stevens's Avatar
ed stevens
Cruising
Default Help with Clevis
I am the guy that is change from mechanical brakes to power brakes and I have run into a snag. I realize that I mus t move the clevis on the brake pedal from the top hole to the bottom hole but I seem to be a little short on room. The pin is hitting the support. There does not seem to be enough room to remove the pin with out taking alot apart under the dash, Like shifting the brake pedal. Could someone please give me a suggestion. :confused:
