Oil pressure to high?
Old May 6, 2002 | 09:09 AM
Johns vette's Avatar
Johns vette
Default Oil pressure to high?
I have a new oil pump in a rebuild with about 600 miles. Even when the engine is warm it's pushing 40lbs at idle and about 70-75 lbs while driving. I'm pretty sure the guage is correct because before the rebuild it read 40lbs while driving which is normal. Is this going to be a problem? :seeya John
Old May 6, 2002 | 11:27 AM
verskel's Avatar
verskel
Default Re: Oil pressure to high? (Johns vette)
With the same oil & same type of pump ???
....don't think it'll hurt anything - sound like you have a "high-volume" oil pump. :confused:
Old May 6, 2002 | 11:41 AM
Tom73's Avatar
Tom73
Do you know what they used in the rebuild. Sound like a high pressure pump and maybe even a high volume pump. Chevy only used a high pressure pump on a handfull of solid lifter engines and never use a high volume pump. A lot of different opinions on this but some feel that it could hurt the lifters and the drive gears for the pump. For street use, the stock pump is more then enough.
tom...
Old May 6, 2002 | 03:06 PM
Tominator's Avatar
Tominator
That's similar to mine, I got over 4,000 miles on it sense the rebuild. This has been posted before and it is that way for a number of people so you are OK.
I'm sorry I don't have a answer for why it's happing.
Old May 6, 2002 | 05:26 PM
vettedan's Avatar
vettedan
Default Re: Oil pressure to high? (vJohns ette)
Sounds ok!
Old May 6, 2002 | 06:38 PM
Chris Fowler's Avatar
Chris Fowler
Cruise-In IV Veteran
St. Jude Donor '03-'10
Mine's very similar. It was that way when I bought it a year ago.
Been about 8-9k miles since I got the car and at least double that since the previous owner rebuilt the engine...
I guess it's ok. :D
Old May 6, 2002 | 10:23 PM
Johns vette
Hey Thanks people! That makes me feel a whole lot better! Later! :seeya
Old May 7, 2002 | 05:05 AM
Jvette73's Avatar
Jvette73
No problem with that oil pressure. Just pray you have good valve seals. If the valve seals arent up to par you may have more oil getting down them into the cylinders mainly because there is more likely to be that much more oil pumped to the top end. Good seals solve the problem should you run into it.
Old May 7, 2002 | 08:41 AM
Johns vette
Default Re: Oil pressure to high? (Jvette73)
Jvette73 I am having a problem with oil burning and was wondering if it was the valve guides. I have new s/r World heads and was thinking I got some bad heads. Looks like I will be changing the guides/seals. Any ideas on good seals? Thanks! :D
Old May 7, 2002 | 09:07 AM
Matt Gruber's Avatar
Matt Gruber
when i was 16 i had a 56 ford; i did not like the oil pressure so i drained it out :yesnod: i put a brick on the gas pedal and ran off. :jester
Old May 7, 2002 | 05:08 PM
Jvette73's Avatar
Jvette73
All I can tell you Johns vette is that you need to get positive type seals. These are the type that lock down over the guide to provide a positive seal for the guide. I was using umbrella seals when I first went to a high volume pump and was fouling plugs and burning a qt. every 300 miles. I switched to positive seals and corected the problem completly. I suggest checking with the manufacturer of the heads to see what type seals they would recomend. I used Crane street performance seals since the fit my guide diameter. Valve stem diameter and outside valve guide diameter at the important measurements you'll need to know in order to get the seals for your particular setup.
Old May 7, 2002 | 05:15 PM
Fevre's Avatar
Fevre
Default Re: Oil pressure to high? (drives61)
drives61
step away from the crack pipe.... :crazy:
Old May 7, 2002 | 05:19 PM
Noel Carboni's Avatar
Noel Carboni
These readings would be normal if a high pressure/high flow oil pump was used during the rebuild. Mine runs about like that.
A too-high oil pressure should not harm anything, as long as it's not due to something being blocked.
-Noel
Old May 7, 2002 | 05:26 PM
Darkness's Avatar
Darkness
I don't know adout the engine but high pressure will brake your oil faster than conventional pumps, try to check the viscosity of the oil after 3000 mi on high press and remember the old one, I can assure you that this one is much more broken or liquefied than the previous one. Just beware because liquefied oil doesnt give enough lube characteristics as good oil. It will be like using disel istead of oil!
Paul
Old May 7, 2002 | 05:35 PM
woodenichols's Avatar
woodenichols
Default Re: Oil pressure to high? (inferno-vette)
Mine has run at 70-75 since the first day we cranked it! After warm up and with recent warmer weather it will drop a little! :jester
Steve
Old May 7, 2002 | 10:20 PM
Johns vette
Default Re: Oil pressure to high? (woodenichols)
Jvette73 Thanks I'll be calling the manufacturer for the seals. drives61 did you ever consider getting professional help? :lol: Just kidding! I laughed when I read your post. Thanks again people!!! :D
To Oil pressure to high?
